Color Questions
Hi,
I have a 1975 Porsche 911 Cabriolet that I'm considering to re-paint. Can you match either of these colors? Can you recommend a shop or shops in the Washington DC area? Lime Green Metallic Azure Blue
“If you don’t know where you’re going, you’ll end up somewhere else.” —Yogi Berra |
Black and Blue
Lynn-75,
If you can get the paint codes for the color you want, the paint shop should be able to match. Paintscratch.com is a pretty cool resource for getting the code of the color you want. The only blue close on their site is this: Cobalt Blue Metallic Clearcoat - 2006 color - Code = 3C8/F6 and according to this thread Viper Green vs. Signal Green Kelly, Viper and Emerald green have the same code - L225 I hope this helps. Be sure and post pics of the project. Is your 75 a targa converted to a cab?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver Last edited by Kemo; 12-14-2005 at 11:24 AM.. |
Hi Kemo,
Thanks for the info. My car is a 1975, re-bodied with a 1987 cabriolet body and a 1985 3.0 engine. Trying to figure out the right parts is a trick. Thanks, Lynn
Black and Blue
you must have got the moritz-max as opposed to the max-moritz
![]() good luck with your project and remember to post some good pics, if you can, along the way.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
