barney911rs's Avatar
Bosch spark plugs
ok I'm sure I'm behind the times on this, but I found out today you can not get the old cooper Bosch Super plugs anymore. There is a replacement: Bosch Super Plus
Yttrium-enhanced copper core center electrode
I've always used a cooper plugs. Has anyone used these new plugs and have an opinion?
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 10-02-2008, 09:51 PM
old man neri's Avatar
I think NGK still make coppers.
Old 10-03-2008, 03:27 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Autolite makes coppers too. Most people laugh at the thought of using Autolites, but they are good spark plugs. I use the 64's on my 3.2 Motronic. As for the Bosch, I haven't used them. But if it's their copper replacement, it should be fine. Bosch knows there's still ALOT of cars on the road that need copper plugs to run properly
Kevin L
'86 Carrera "Larry"
Old 10-03-2008, 07:43 AM
I've been told NGK's are the hot setup right now. I don't remember which NGK's I have, but they're going in at the next valve adjustment.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 10-03-2008, 07:58 AM
abit off center
cgarr's Avatar
Yep, Hot set up is NGK's in fact they are soooo good I use 12 of them!
______________________
Craig
G2Performance
Old 10-03-2008, 08:03 AM
Friend of Warren
I've run NGK's in my 911's for 8 years with no problems.
Kurt V
Schleprock
KTL's Avatar
You should have BPR6ES if they're the standard plugs and not the fancy V-Power or Iridium plugs
Kevin L
'86 Carrera "Larry"
Old 10-03-2008, 08:56 AM
Which NGK, and is it cooper or Platinum? I've heard that platinum plugs are fine for fuel injected engines. I've only had two 73's, and actually the same motor in both cars and it's carbureted. Since they tend to run on the rich side at the bottom end (to keep from going to lean at the top end) they tend to foul the platinum plugs. Dazed and confused.
John Snodgrass
Old 10-03-2008, 09:07 AM
gtc gtc is offline
abides.
gtc's Avatar
Get the cheap NGKs. They are ~$2 each at any Autozone or CSK and work, period. Seriously, they last a surprisingly long time for me. BPR6ES for the 3.2s, but I don't know about the other engines. Don't forget to gap them.
Graham
1984 Carrera Targa
Old 10-03-2008, 10:03 AM
Friend of Warren
In my 72E I ran NGK BPR7ES. In my '86 3.2 I run NGK BPR6ES which is a bit hotter plug. Both are copper core.
Kurt V
Old 10-03-2008, 10:12 AM
Schleprock
KTL's Avatar
Just use the basic/standard NGK. They're copper. Check out NGK's site. It's quite informative
http://www.ngksparkplugs.com/tech_support/spark_plugs/index.asp?mode=nml
and do a product search to see which plug they recommend for your engine.
And BTW, don't think that all fuel injected engines don't mind the use of platinum. Some do not like platinums. I don't know specifically why. But I do know my friends who are auto techs tell me they get driveability/poor performance problems in cars all the time. The first thing they typically check is to see if the vehicle has been "upgraded" with platinum plugs. Original spec non-platinum plugs are installed and problem solved. I bet if you do an Early_S_Man search with the term "platinum" you will find the answer. Warren's electrical knowledge is staggering!
Kevin L
'86 Carrera "Larry"
Old 10-03-2008, 10:14 AM
Kurt/Kevin,
Thanks for the info. I still have a few sets of the old Bosch plugs in my parts boxes. There may be more in the trailer, I'll have to look. But I'll definitely check out the NKG.
John Snodgrass
Old 10-03-2008, 10:17 AM
goat's Avatar
I too just switched over to the NGK's about a week ago. No problems for me.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 10-03-2008, 10:22 AM
Make Bruins Great Again
Por_sha911's Avatar
I've been running NGKs and they're fine. Getting back to the original question, has anyone used the "new & improved" Bosch Super Plus?
Joe
Old 10-03-2008, 06:30 PM
rib rib is offline
rib's Avatar
I use NGK Plugs and they work great. Did 1800 mile round trip this summer with no probs.
Old 10-04-2008, 09:57 AM
plymouthcolt's Avatar
I switched to NGK as finding the Bosche locally was impossible without resorting to mail order. So fara so good.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 10-04-2008, 10:28 AM
Thanks Joe, I'm still waiting to hear that answer as well. Not putting down the the NKG's, but would like to hear about the new Bosch.
John Snodgrass
Old 10-04-2008, 03:26 PM
rnln's Avatar
I hope people don't mind I am asking a silly question. What differences will it make if I am running a little hotter or little colder plugs?
Fat butt 911, 1987
Old 12-11-2008, 09:49 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
NGKs are what comes in the tune up kits from the host.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-11-2008, 08:20 PM
I am thrilled that the Bosch are made in Brazil and not just a pure copper electrode. I understand their coating makes it last longer but 15-30K in my daily driver is fine with me. More frequent replacement in my Porsche is also agreeable to me. I have been using the NGK V-Powers but would rather the standard NGK in my daily driver. Where can I pick up the standards online because nowhere near me carries it.
Old 12-11-2008, 08:56 PM
