Air Medal or two
afterburn 549's Avatar
inductive fired coils ?? (question for those in the know)
It would seem to me if a timing lite can be fired by a inductive trigger that a separate coil (s) could also be done this way creating a super cheap dual plug system........The spark from the original coil would also fire the sister coil. Make sense?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-11-2005, 10:45 PM
Early_S_Man's Avatar
Porsche Crest
Triggering a second coil is a trivial and inexpensive part of a twin-plug project! The distributor is usually the BIG expense.
Now, if you are talking about an inductive pickup on six spark plug leads, such as the following coil, and a dedicated second coil to the lower plug in a particular head x 6 ... that just might eliminate the need for an ultra-expensive 12-tossle-head distributor! It might not be trivial in co$t, but it shouldn't cost anything near $3000, either!
http://www.allelectronics.com/cgi-bin/category.cgi?category=278&item=VT-27&type=store
http://www.datatronics.com/pdf/pt273_series.pdf
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-11-2005, 11:03 PM
Air Medal or two
That's what I mean, just fire six more coils, all else stays the same. I do not have the expertise to know what it would take...just seems real possible.
Old 12-12-2005, 09:01 AM
Air Medal or two
I really want the electric guru's to step in here......... and say why or why not has this /can this be done??????????
Old 12-12-2005, 10:47 AM
Air Medal or two
Bump??
Old 12-12-2005, 07:13 PM
Air Medal or two
Early S man ,will these units fire a coil?? seems too ez, if they did double plug will be pc of cake. thanx
Old 12-17-2005, 09:32 PM
