backdating heater question
I've done a search but can't come with anything about this. Does the engine have to be dropped to change the side tin when backdating the heater?
No, its quite easy. The only thing I had to worry about on my SC is loosing and rotating the oil fed tensioner switch that was too close to the new part. Very straight forward. Try re-wording your search there are tons of threads on this subject.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Thanks, I think I have read everything on this.
1976 3.2 911s cabrio slantnose |
you don't have to drop the engine. You'll probably have to beat in the area facing the dizzy. I used a large round piece of wood laying against the steel and whacked that.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
are you planning to sell your heater blower in the classifieds? there are always a few folks looking to update heat..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Yes, it works fine and if it can not be used as a replacement for the fresh air blower i will.
1976 3.2 911s cabrio slantnose Last edited by 76carrera3.2; 12-18-2005 at 06:06 AM.. |
Backdate Heat
76--
You don't need to drop the engine. Very straight forward to do the backdate. The only problem I had was with the drivers side duct. As Ronin said, the only problem is fitting that duct around the dizzy. I tried to pound on the duct with a BFH and couldn't get it to fit properly. I eventually got a duct made of carbon fiber (I wann't looking for CF...one came up for sale in the classified and I jumped on it). new duct that didn't fit Original duct--note the narrower flange to fit around the dizzyother than this issue, the backdate is straight forward. Good Luck, Alan
1988 924 S 500 in US Black (the only color) 82 SC Guards Red/Black . (Sold) SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade |
