Running Without O2 Sensor
I pulled the O2 sensor on my 87 Carrera this morning in preparation to have my "custom" exhaust system installed this coming Wednesday. I'm trying to do as much disassembling as possible to save on some labor costs
![]() Does anyone know if there are any negative affects to driving my car without the O2 sensor. Seems to run and idle just fine without it ![]()
Mark 1987 Carrera 2018 GMC Sierra Denali 2500 Duramax 2012 Harley Davidson FLHX Street Glide |
The motor will not run as efficiently, with decreased performance and increased emissions...
commandant of the compound |
Twins are more fun!
With an O2 sensor, the DME forces the engine to run around the Stoich region, for best economy. Removing it makes your idle and part throttle mixture run richer, slightly improving performance at the cost of fuel economy.
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
If I understand correctly, deleting the O2 sensor will cause the car to run richer..right? I will running European Racing headers into a VERY short muffler system. Much like the one Steve Weiner has on his website. Maybe SW can program the chip to compensate an O2 delete
IIRC - Bruce Anderson suggested the '84 - '89 cars get premature valve guide wear due to too much fuel from the factory. I wouldn't want to run without an O2 for very long...
Nick '85 Carrera |
Large Registered Member
Bursch sells a pre-muffler that has the o2 hole for the sensor. I've run mine without the o2 sensor connected, and the idle and lower rpm performance is much better. However, at the cost of about 20% drop in fuel economy....
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
boxer6 this site ? http://www.rennsportsystems.com/ which muffler were you saying ?
Richer than Stoich means rich of peak EGT, higher CHT's, higher oil temps, shorter valve guide life, increased oil consumption.
Even if your 02 sensor is connected it could still be running too rich if your base mixture is set too rich, beyond the narrow range that your 02 sensor can correct. You can Google rich of peak EGT to see the charts and how it effects air cooled cylinder head temps. Last edited by stlrj; 12-27-2005 at 04:00 AM.. |
During my days of building Chevrolet engines, I have "washed" rings from running REALLY rich, but I haven't heard of "washing" valve stems ![]() I love this site...I'm always learning!
But high cylinder head temps have been known to prematurely wear out valve guides.
Joe |
and head studs...
