| NorthernThrux |
03-31-2021 02:26 PM |
This is a very old thread that I stumbled upon. But it has some incorrect info, so I just wanted to correct that. I have owned 9113300854 since 2014 and the correct engine number is 6331315 as verified by the factory and it is still in the car. Likewise, according to the Early S registry annual listing, 9113300861 has motor 6331329, 9113300902 has motor 6331421 and so on. All the engine numbers listed here should start with 633. Brian goofed in transcribing the engine numbers.
Just fixing this up for posterity.
Originally Posted by fryardds
(Post 2312052)
According to the latest early S registry list I have the following chassis and engines are listed together (note: these combinations might not all be matiching #'s):
9113300854----6631315
9113300861----6631329
9113300902----6631421
6631126----9113300720
6631164----9113300752
6631169----9113300755
6631174----9113300756
6631184----9113300759
6631161----9113300774
These #'s cast a little doubt on 870 matching with 1154 but strange things happened sometimes when these cars were built so you should get a CoA to know for sure.
