KCinBR's Avatar
XM Radio where/how to mount??
Any of yall have Satellite radio mounted in your 911 (1988 model)
Santa is bringing me one (Delphi Skifi 2)and would like to see the mounting on others cars.
Pics of the install would be greatly appreciated.
Thanks............................KC
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 12-24-2005, 02:42 PM
The XM Rodie fits pretty well in this space. I wired it in without much care but gives you an idea of the fit. Antenna goes on the dash because it left very fine scratches on the hood when mounted there. The problem with the roadie was its reception is run through an fm radio band and needs to be fixed to a new station due to local travel.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 12-24-2005, 07:29 PM
I have done a few of these installs, though mainly on Toyotas. For best reception, the antenna or antenna ground plate should be mounted on a wide, flat area like the roof or other equivalent body panel. A second choice would be on top of the IP.
Sherwood
Old 12-24-2005, 11:51 PM
Originally posted by jtratza
......... Antenna goes on the dash because it left very fine scratches on the hood when mounted there. .......
I disagree....I had my gps antenna on my 911 for months & an XM has been on my wife's 3 series for over a year, NO scratches what so ever, even under very close inspection.......
(a thread on it from a bit ago... XM radio antenna)
Chris
'97 Boxster (Sold)
'84 Targa - now a Cab (finally) Sold
1963 VW Transporter - Modified https://www.thesamba.com/vw/forum/viewtopic.php?t=668542&postdays=0&postorder=desc
Old 12-25-2005, 07:36 AM
Chris, you need to drive and corner faster so it would move on the hood I'd guess. Just kidding. Maybe its the red paint but mine left scratches so I moved it.
Old 12-25-2005, 08:20 AM
Why wouldn't you just flip it around and mount it on the cowl? I would think it would look better there and not break up the hood.
Old 12-25-2005, 08:47 AM
Mine was on the cowl. Maybe that's why it left scratches since it wasn't up against the fresh air intake vent.
Old 12-25-2005, 08:57 AM
Mine wasn't up against the fresh air vent. The hood opens and closes without any contact with the antenna. I tried it on the cowl but felt it was too unsightly to see the wire....I hid the wire inside the hood and ran it so you never saw the wire. I also think it is less noticeable on the hood than the cowl.....
The wire and antenna were secure so even if the hood was opened, it never moved..ergo no scratches.....I also have an XM satellite on my red M roadster, and there are no scratches on it either....perhaps the magnet is stronger on my antenna than yours was, so it doesn't move......(and I drive my M faster than my 911... )
Chris
'97 Boxster (Sold)
Old 12-25-2005, 09:12 AM
