H.G.P.'s Avatar
Are there any "regular" early (1969 early) parts that I should stock up spares for?
Are there any "regular" maintenance items that I should start to stock up on due to possible NLA or coming NLAs? (i.e keep spares for)
I ask because since the rebuild last year nothing (except oil changes) has come up.
Spark plugs don't look like they'll ever be a problem (I hope).
How about dizzy cap?, rotor, or even points?
Also, ask this on another thread, what about pulley seal? flywheel seal?, tranny seals? I believe my flywheel seal is NLA
(I've already found that the CV flange is NLA, but I guess this is not a regular maintenance item (or is it)?)
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-31-2005, 09:59 PM
dtw dtw is offline
GAFB
Have all the above and will send for free...will just need your name and location...
Several BMWs
Old 12-31-2005, 10:38 PM
Gon fix it with me hammer
svandamme's Avatar
Re: Are there any "regular" early (1969 early) parts that I should stock up spares for?
i don't see dizzy stuff ever becoming a problem
it's a 6 cyllinder cap , with points, it's not 911 specific gear
any 6 cyllinder car has used those for a long time
seals, that's another thing i can't see as beeing a problem
there's company's that make seals, and have large stocks
all you need to do is tell em what size, and they'll get as much of them out of the warehouse as you want or can carry...
PET actually lists the size of every seal :
69 flywheel seal
65x86x10...
not a problem
the maintenance and wear and tear things won't go NLA anytime soon... at least not in the real market, Porsche might have some things go MLA, but there is enough aftermarket for these cars that will provide the goods...
and then there's later year cars that can be used to upgrade or replace things with if early stuff becomes a problem...
at worst, little tidbits , trim and detail stuff will be harder to score
but not the maintenance stuff...not even the engine stuff.
i do not see a problem, at all
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-01-2006, 07:58 AM
H.G.P.'s Avatar
Re: Re: Are there any "regular" early (1969 early) parts that I should stock up spares for
69 flywheel seal
65x86x10...
not a problem
I tried to look up the Pelican seals for early 1969, and they have one for the flywheel as listed as "undersized." NLA
But thanks for the information, most encouraging.
1969 911 E Coupe
Old 01-01-2006, 03:02 PM
svandamme's Avatar
pet says you need nr : 999 114 057 50
enter that number in the site
and it comes up with part superceded by : 99911305752
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=see_more&please_wait=N&db_record_number=42336&PART_SEARCH=Y
i'm on my laptop , don't have the latest pet on it, the latest one is on my desktop pc @ work, that one would actually tell the supercedes
Stijn Vandamme
Old 01-01-2006, 11:50 PM
