Rolon's Avatar
oil hoseunder car
hi every body I wonder if somone has a oil line diagram. My car has one hose under the the leaking oil went I start the car. I want kown were comfrom and were it go.
A L Rolon
Old 12-19-2005, 09:03 PM
ianc's Avatar
Hi Rolon,
Can you please try a little harder with these sentences? I really can't quite make out what you mean... Pics would help also...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 12-19-2005, 10:46 PM
randywebb's Avatar
maybe you have a friend in PR who can help with describing the problem?
or if you speak Spanish you could try that - somebody on the bbs could translate
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-19-2005, 11:31 PM
Rolan
Tell us what year and model you have and we can post an oil line diagram for your car.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-20-2005, 03:01 AM
Rolon's Avatar
I live in ny
this is a picture
A L Rolon
Old 12-20-2005, 07:57 PM
Rolon's Avatar
I found a diagram in a book, and look that is the crank breather hose
A L Rolon
Old 12-20-2005, 08:00 PM
Rolon's Avatar
My car is a 1977 911s Targa,
A L Rolon
Old 12-20-2005, 08:02 PM
randywebb's Avatar
your L tubes may be leaking also
Old 12-20-2005, 09:06 PM
Rolon's Avatar
what is a L tubes
A L Rolon
Old 12-20-2005, 09:15 PM
Rolon's Avatar
The hose come from the oil cooler
A L Rolon
Old 12-24-2005, 10:17 AM
Rolon's Avatar
here is other one
A L Rolon
Old 12-24-2005, 10:18 AM
Rolon's Avatar
where it goes ?
A L Rolon
Old 12-24-2005, 10:20 AM
I don't have a '77, but it looks like its the overflow tube from the air cleaner. There's a crankcase vent hose from the oil filler tube that connects to the air fliter housing. If the oil level is too high and/or you have excessive blowby, oil will be forced into the air cleaner housing. From there, it drains onto the ..... floor. One solution is to run the tank about 1/2 -1 quart below full. Another solution is to install a oil breather/separation tank between filler neck and the air filter housing. If it's excess blowby (from worn rings), well..... you know what.
Remove the cover from the air fliter housing and take a look. If it's wet inside, that's where its coming from.
Sherwood
Old 12-24-2005, 11:44 AM
Rolon's Avatar
thanks for the information I will take a look on the air cleaner and let you know.
thanks again
Rolon
A L Rolon
Old 12-25-2005, 09:07 PM
Rolon's Avatar
thanks to every body, Sherwood was right is coming from the air cleaner. the other day I change the return oil tube and maybe I put to much oil.
thank Rolon
A L Rolon
Old 12-26-2005, 08:56 PM
