Third Brake Light
I have a '87 930 and I want to get rid of that stupid looking third brake light. I don't want to move it to somewhere else, I just want it gone.... I've done the search and that's pretty much what everyone talks about is moving it to somewhere else.
So my question is if I remove the light and cap off the wires won't I have 2 holes left in the engine lid? What did you guys do with them? Is there a cover that could be bolted in place or something? I didn't want to get into all the body work stuff.
Bill 997.2 |
Wont you fail inspection without the third light?
Warren & Ron, may you rest in Peace. |
Nope, we don't have inspections here in Michigan.
Bill 997.2 |
resident samsquamch
I too have and '87 930 and would like to know what's lurking under this horrible looking thing (reminds me of War Of The Worlds). Due to NC inspections, I will be doing the thin LED strip in the rear window, but regardless, this evil eye is coming off!
remove it and have it repainted, i still like mine
Bill,
I would be interested in purchasing your brake light. Please email pakoury@sbcglobal.net with price if you would like to sell. Thanks, Paul
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Paul,
I usually try to hang on to the original parts as much as possible, so it isn't for sale. But thanks for offering to buy it. If I do decide to sell it, I'll offer it to you first. Maybe sand_man would sell you his when he relocates it.
Bill 997.2 |
resident samsquamch
Sorry, but NOPE I'm keeping it. I'd love to be able to hand the new owner (not that there is one) a box full of OEM parts. I usually save EVERYTHING that I take off.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
I used 3-rubber grommets (center is larger) it created a nice high-tech riveted appearance.
You can use general purpose plastic caps (I found them in a hardware store). BTW, the fit need not be water tight since the lid grills is open to the elements anyway... Jascha
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Schleprock
The third brake light periscope shares wiring with the engine bay light that is mounted on the underside of the engine lid. So you'll have to:
1. Cut some wires somewhere or 2. Remove the engine bay light too. That means you'll remove both the periscope and the engine bay light together. There is a male-female harness connector in the engine bay that you can disconnect. Removing both lights allows you to not cut any wires.
Kevin L '86 Carrera "Larry" |
I removed mine.
All,
I'll take some pics and post the results tomorrow. One, you'll have 3 holes left. Two, you go to Sears Hardware, Home Depot or wherever and buy black plastic plugs to push into the holes. Easy and looks much better. I'll point out, however, before someone sees my pic and points it out, that you'll very likely have a ring where the gasket set on the paint. I've buffed as much as I dare and it's still visible. If you remove this light I recommend keeping it. The next owner may want it. Still a huge improvement visually.
His toys - Saving for the next 911. 2007 Mazdaspeed 6 Her toy - 1994 Miata Limited Edition |
Paul -
Not to hi-jack but I have one of these third brake lights, it is near mint condition with gasket, what is your offer ? Todd
1. Disconnect the plugs in the 3rd brake light. 2. Push the wires back through the decklid hole. 3. Electrical black tape the ends of the connectors. 4. Ziptie the wire to itself, which is routed and clipped under the forward most edge of the decklid. Done.
resident samsquamch
+ lurking - contributing
on USA VIN 930 models, when did the center brake light move to the upper section of the rear window?
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
I have this also on my '87 and removed it a few months ago (did the wire clipped to itself bit). Some minor buffing and three Wurth rubber plugs and things looked fine.
However, I have since put on the "baby RSR" wing from Getty so the entire process was moot! I would really like to add the third brake light inside the window, has anyone gone that route? Chris
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Rick,
I think as long as I use black double sided 3M tape I would be ok with the visual aspect. How painful was the wiring? Did you replace the rear window gasket? Thanks, Chris
Can anyone post a after pic to what it looks like with the rubber plugs in place. I would like to see the ring left over too.
Bill 997.2 |
I recently sold my "snorkle" on Ebay for $81 + shipping. And it was slightly damaged. Somebody out there wants these weird things. I was surprised but they do have value. We had the holes welded up and repainted when the car was painted. Not a big fan of plugs.
I recently sold a bunch of stuff that I had sitting around my house for years, waiting to give to that mysterious next owner. I realized I would be giving him almost an entire car of used parts. Now I've got some Christmas money that didn't cost me anything. Last edited by 89911; 12-13-2005 at 06:59 AM.. |
