Price is good, but I'm weary about "you get what you pay for"
What do you think?
David Nguyen 1987 930: 2700 lbs, 408 RWHP/405 RWTQ 930 pics: http://alturl.com/899f9 930 Engine rebuild pics: http://alturl.com/25qcy |
Those Schnell headers have been debated quite abit on here and Rennlist. The consensus is that someone should pony up and buy them and test them...no far no one has. Up for the challenge?
I would Jet-Coat them before installing them, to keep the heat in the pipes and also to prtect the metal and welds. Regards - Yasin
Ole Skool - wouldn't have it any other way |
They'd be fine for a relatively low power CIS setup, but if you are after serious HP development, Marco Menzie is your man. His headers are the best in the industry, but be prepared to pay for it. He uses the best collectors and materials
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
I may pony up for this set instead...a little cheaper and won't hurt the wallet if it failes.
Crotchety Old Bastard
350HP930 has a set of those, purchased on e-bay some time ago for his engine rebuild.
I don't like the angle that the waste gate pipe comes off. In stead of a 90* angle it should be a 45* going in the same direction as the turbo mount.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I'm pretty sure that Albert from goingsuperfast.com makes Schnell's also. 350HP930 bought a set of Albert's that are awaiting the completion of his rebuild. The collectors use to be built like B&B's...actually the whole header was like B&B. Then Vertex started selling them and Albert stopped listing them on ebay or his site(non-competition agreement)? Now Albert is back selling them with a different collector design that is swaged? around the primary tubes. In any case I think it would be prudent to find out if you can jet-hot coat the Inside of the headers regardless of which SS is used, to protect the welds and SS from the heat. The possible problems from cracking headers can be debris from the headers being ingested by your turbo.....ouch! I can say that I recently bought a new turbo drip tank from Albert and the tig quality is excellent. Last edited by 89turbocabmike; 10-03-2005 at 09:45 AM.. |
Good feedbacks guys. Well, I just bought the set including the drip tank. For the price, I think it's good for my purpose (i.e., no track day, occasional drives). Looking from his web site, it looks like he's got a killer 930 setup as well as EFI. Since he 'eats his own dog food', I'm hopping that it's good quality.
Should I wrap the headers or not? |
I would definitely not wrap the headers. I think the small benefit would be far outweighed especially with 304.
The luck for most aftermarket 930 header manufacturers(not including manzie, holcomb and a few others) is they don't get driven often......
One tip, if you're going to use a lamda sensor, move it to after the turbo.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Me like track days
"The problem with both of these header sets is the fact they are 304. The 321 SS have a tough enough time handling the heat. I have a set of powerhaus 321's (I believe B&B made them)that are a perfect example of the cracking that can occur and this is from just daily driving with no track time other than 2 auto-x events.
I'm pretty sure that Albert from goingsuperfast.com makes Schnell's also. 350HP930 bought a set of Albert's that are awaiting the completion of his rebuild. The collectors use to be built like B&B's...actually the whole header was like B&B." -------- So which is better for track applications........321 or 304?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
![]() Both materials are a poor choice when EGT's wind up in the 1550-1600 deg range that is a result of higher-than-stock boost levels. If one really wants a durable exhaust,.....be prepared to spend some $$$ and have something made from Inconel. Thats really the only way to do this right.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Me like track days
That is exactly what I have heard. I shudder to think what inconels cost.
Given the choice of 321 or 304, which would you pick?
Inconel is king!! |
![]() Remember, each time one welds a crack (TIG or MIG), the parent metal hardens on each side of the weld and becomes easier to crack. Its a downward spiral. 321 is better than 304 in these applications, for sure. Never have a Ceramic-Metallic coating (Jet-Hot type stuff) applied to the inside of any pipe used on turbocharged cars because WHEN it flakes off, that material destroys turbochargers. BTDT.
Me like track days
Excellent advice....as always.
Steve, what (approx) do a set of inconels cost? Can you source a set?
Its been many years since I had a set made up and steel prices have really gone up over the past 24 months.
I think one would spend somewhere north of $ 3500 for a set of heat exchanger/headers for a car like yours. Let me talk with some of my specialty fabricators about this.
Me like track days
(Unfortunately) I need them with heat --
Oh yes, thats a given,....
There's some good info on Inconel at www.burnsstainless.com
BTW, $3500 sounds really good for an custom inconel header, especially if they use the Burns collectors.
BTW, $3500 sounds really good for a custom inconel header, especially if they use the Burns collectors.
