911Velocity's Avatar
Spec clutch for modified 915 trans
Just spent two days breaking in , testing and getting used to the Spec stage 3+ clutch package I installed in my 911. This is as close as I would ever want to come to a race clutch driven on the street. There is really not much in the way of slipping the clutch on standing start takeoffs and holding a hill is very tricky more like moving from stop to slow forward and vice a versa. It pretty much is a go no go situation but I am told it will get a little more street friendly as time goes on. It does feel like it will hold 600 HP though so I guess you take the good with the bad. Has anybody any experience with this company?
Best regards,
Gerry
84 911 Carrera (Supercharged), 67 427 Vette , 67 XK E-type Rdstr., 56 Vette
06 Cayenne Turbo S, 08 Vette Coupe, 57 Vette, 65 Chev Nova 327 4spd
65 Chev Nova 385 Race, 85 Chevy Rollback
97 Ford Exp. EB, 90, 91 Toy PU
Old 12-29-2005, 01:01 PM
Somewhere in the Midwest
MotoSook's Avatar
Is that the solid disk kit? Or does it have a spring center? We ere going to use a SPEC clutch package for a friend's car, but it wouldn't work with what we were working with. Yet I am curious to know more about it.
Old 12-29-2005, 01:04 PM
Here is what I pulled from the website (www.specclutch.com). Time will tell how much is true.
Stage 3+
Features a streetable high clamp pressure plate and full face carbon semi-metallic disc. Listed as an upgrade to the stage 3, it offers torque capacities more comparable to the stage 5 but with drivability equal to, and in some cases better than, the stage 3. The high capacity and excellent drivability characteristics of this clutch is a result of years of research and development for this SPEC exclusive disc compound.
Best regards,
Gerry
Old 12-29-2005, 01:15 PM
MotoSook's Avatar
Cool. Here is what I got from the link for the Stage 3:
Types of Driving: Street, Drag, Drift, Road Race, Rallye, Pulling, Autocross
For heavily modified street and race engines. Offers sufficient daily drivability with a comfortable pedal feel and quick engagement. Offers good wear characteristics under low and high stress usage.
High clamp pressure plate, 4 or 6 puck carbon semi-metallic friction with high torque sprung hub and disc assembly, bearing and tool kit. 6 puck is standard on most applications
So now I have to ask you what engine you are running?
EDIT: Nevermind, I see in your sig you have a supercharge 3.2. How much power?
EDIT2: I should say that SPEC was very easy to work with. We went through some iterations/corrections with them, and they were friendly and responsive when I stayed on top of them. Like most shops, they can get busy and caught up on other work, but they were pretty good to me.
Old 12-29-2005, 01:27 PM
Right now at 9 lbs boost > 400 RWHP, at 13 lbs boost should be about 526 RWHP. I want to get to 600 RWHP or more.
Best regards,
Gerry
Old 12-29-2005, 01:45 PM
MotoSook's Avatar
Excellent! I look forward to your long term report on how the SPEC disks performs.
Old 12-29-2005, 01:48 PM
