Sorry to drag up an old thread but I am about to do the front Tarett install and I am not exactly sure how you get the triangulated nut plate adapter into place.
Must the gas tank be removed?
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 02-19-2006, 10:32 AM
Chuck Moreland's Avatar
You do not have to remove the tank. Use a coat hanger to fish the plate behind the tank, then grab it using a screw fed through from the wheel side into one of the weld nuts.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-19-2006, 11:58 AM
North Coast Cab's Avatar
I used a telescoping magnet thing to hold the inside plate. I installed a couple bolts without the outer ring and then installed one bolt through the ring. That held the inside plate in place while I added the outer ring. Overall the install was fairly easy front and back, but there were a lot of parts.
John
1985.5 944 GTS
Old 02-19-2006, 12:14 PM
Chuck, John, Thanks....both sides are done. I used a combo of the coat hanger and needed the magnet on the drivers side where wires made it toughter.
Old 02-19-2006, 02:29 PM
Wer bremst verliert
JohnJL's Avatar
Little more help...
No instructions came with the Tarett thru-body plate kit and the pics on this thread and others are a bit vague...am I right in interpreting the plate goes on the INSIDE of the fender (as opposed to the factory kits and pics in the Tech article) that show the factory install on early cars had plates on the wheel-side of the fender?
I see the "vestigal" imprints and have ground away the undercoating there to get a good mount, will prime and paint prior to final assemply.
thanks
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-29-2006, 08:18 PM
