How do you bed PFC 97's?
I can't seem to find instructions in the box or on the site. This is my first set. Do you bed them the same as other pads?
Thanks,
Sean
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 07-29-2006, 12:03 PM
Cory M's Avatar
http://stoptech.com/tech_info/wp_bedinperformance.shtml
I follow this procedure for race pads. I just do the first set of 10 stops from 60-10 and don't do the 4 80-10mph stops. I have been told that this is okay because the 97's are preburnished and there aren't any good roads near me to do the 80-10 stops anyway. I have never had a problem with them using this procedure.
Old 07-29-2006, 12:51 PM
They are pre-bedded....use them as you normallly would for a couple laps...come in, for 5 minutes or so.....go out and race on 'em....I have been using PCF 97 and 01 compunds this way for 2 seasons and they have given me excellent service.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 07-29-2006, 01:09 PM
Cory M's Avatar
They are preburnished - meaning the pad material has been heated up to operating temps at the factory. I believe they should still be bedded in to transfer the pad material to the rotor properly which is why I use the 10 stop method I described above. Maybe just running them for a session is good enough, but bedding them in properly is pretty easy and you have nothing to lose by doing it.
Old 07-29-2006, 08:04 PM
