Got the engine out of the car yesterday and today it went on a stand. I proceeded to take off the pressure plate to get to the clutch because was a pile of little bits and shavings present. Sure enough, the clutch disc was down to the rivets. I don't know if the flywheel should come off for resurface or not. Could someone please advise?
jt -84 targa |
UFLYICU
For all the trouble you gone through so far, it would drive you nuts if you put all back together without resurfacing the flywheel. It can't cost much. Do it.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
IMO, that flywheel is toast. Don't think a resurfacing is possible without exceeding the spec. Definitely pull the flywheel and have it measured to see if it's salvageable; typically when you let the clutch go down to the rivets your buying a flywheel.
ßrandon |
I would at least resurface it to see if it is in specs.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
It's resurfacing itself that is the real problem. Surface is often severely hardened and you need expensive CerMet cutting tools in order to penetrate trough it.
Thank you for your time, |
...and once the surface hardening is cut-through for the re-surfacing process...it would be "good" to re-establish a "hard" surface again..
plus...not just check if you're still in thickness spec..but if you're completely square on the re-surface. Lots of "checks" to do... I don't trust many guys nowadays and always end up checking more than I had to... ( or go new ! )... - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks for all the replies. It sounds like I'll be pulling the flywheel and getting it checked.
Is there any advantage in a 'power' clutch kit vs. original? It seems the clutch disc is different. The following is fs on evilbay for $309+ship:
Seems the rivets are all one one radius. If they haven't dug a deep groove I would have it resurfaced. Mine was some 30 or 40 bucks here in California with its inflated labor and shop rates. So it is well worth a try. Find a good mom and pop machine shop - they'll tell you if it meets specs afterwards.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
