safe's Avatar
How to remove top strut nut.
Hi
Do I need a special tool to hold this while removing/torquing up this nut?
Magnus
Old 12-19-2005, 04:05 AM
You can use an impact wrench (best), or like I did before I acquired one, a pipe wrench to hold the large washer in order to keep the shock from turning. Wrap the pipe wrench in a shop rag if you don't want to mar the large washer.
Old 12-19-2005, 04:20 AM
durn for'ner
livi's Avatar
Hi Magnus,
I did what Keith said. Worked fine.
I see you have already flattened out the little bent part...
Markus
Resident Fluffer
Carrera '85
Old 12-19-2005, 04:42 AM
naparsei's Avatar
Yep, you flattened the little locking part. I just used channel lock pliers to grip the washer, and a big rachet on the nut - pretty straightforward.
'74 Euro Carrera * '64 356SC Coupe
Old 12-19-2005, 05:47 AM
david.avery's Avatar
Mine was seized, I spent hours trying to get it loose, then I borrowed a neighbor's 500 ft lb impact gun, removed it in 5 secs.
I then bought my own
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 12-19-2005, 07:01 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
Use penetrating oil and follow the suggestions.
Surprisingly, the Bentley refers to the spindle as a 10mm on page 401-7 with a torque of 59 ft-lb.
This nut looks bigger to me than 10mm.
Any thoughts? What size is the actual spindle thread?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-19-2005, 07:26 AM
Magnus,
I bought a cheap spanner wrench set (3 sizes) at Harbor Freight. You probably don't have HF there, but a set of 3 different sixes cost me about $12. I have had other uses for them from time to time. I had somebody hold the spanner while I turned the nut. I did it with a pipe wrench the first time I tried it & messed up the big washer, which I didn't like.
Marv Evans
'69 911E
Old 12-19-2005, 07:51 AM
The air compressor driven impact gun is what I call the "marriage saver."
It lets you spend less time on the car, more time with your spouse, who will then agree to have you spend more time on the cars, buy more tools, and more cars, to achieve perfect harmony in a marriage.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-19-2005, 09:38 AM
randywebb's Avatar
Marv - do you have a pic of what that spanner looks like?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-19-2005, 11:14 AM
ianc's Avatar
Actually, it is a bit of a fiddle, but you can use the fan pulley spanner that comes with the took kit to hold the washer by the slot in its side while you have a helper loosen the nut. It's a 22 mm.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 12-19-2005, 11:38 AM
safe's Avatar
OK, I don't have impact wrench yet. Thinking of buying an electric one, my compressor are to small to be useful, I think.
I'm buying a 2" pipe wrench tomorrow
Ianc, I don't have a fan pulley wrench
I had to improvise one last time I needed it.
Thanks!
Magnus
Old 12-19-2005, 12:02 PM
safe's Avatar
Update: 2" pipe wrench did its business
It also worked fine to remove the balljoint from the control arm.
Magnus
Old 01-02-2006, 12:30 AM
