-   -   Re-Anodizing Alloy S Calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/259265-re-anodizing-alloy-s-calipers.html)
jkolk 01-04-2006 02:12 PM
Does anyone have experience getting this done? How do you get the guide pin out the fits up in behind the piston?
Or does anyone know a shop that will refinish them?
Grady Clay 01-04-2006 04:00 PM
It would be interesting to see if this is possible. I don’t
think the calipers were originally anodized. Yes, there
was a very thin coating (similar to on a Fuchs alloy
wheel but thinner). That coating rapidly changed from
clear to a light amber with heat and age.
If your goal is to reproduce exactly the correct finish,
there are 911s with un-molested original finish calipers.
You could do a great service by investigating and
publicly documenting this.
Here is one I imaged last week.
http://forums.pelicanparts.com/uploa...1136418458.jpg
Clearly it has had the surface cleaned.
Best,
Grady
Bill Verburg 01-04-2006 04:09 PM
This is new old stock
http://forums.pelicanparts.com/uploa...1136419675.jpg
Grady Clay 01-04-2006 04:34 PM
Bill,
WOW
What I’m used to seeing in service were probably coated with either a paint (laquer?) coating like the Fuchs or the Tectyl “one-season” undercoat that Porsche sprayed everywhere under the 911.
NOS spare parts almost certainly weren’t coated with anything.
If I were judging Manhattan, I would expect to see degraded original finish and coating (or likeness) for a close to perfect score.
Best,
Grady
