-   -   Torque Value for top Nut that Secures Shock? (http://forums.pelicanparts.com/porsche-911-technical-forum/259433-torque-value-top-nut-secures-shock.html)
IAN 01-05-2006 02:39 PM
What is the torque value for the large nut that secures the shock.
This is the nut that is inside of the front trunk.
I have Boge struts with bilstein inserts.
1972 2.4 T
Thanks,
Ian
yelcab1 01-05-2006 03:45 PM
Cannot answer your question, Here is what I do:
I count the number of threads exposed above the nut before I take it off, and make sure the same number of threads are exposed after I put it back with my air impact wrench.
This only works if you are not swapping struts types, kinds, and others.
David E. Clark 01-05-2006 04:36 PM
SmileWavy Here are all the tightening torques for the front axel and steering. Hope it helps.
http://forums.pelicanparts.com/uploa...1136507238.jpg http://forums.pelicanparts.com/uploa...1136507652.jpg
IAN 01-05-2006 04:54 PM
One More Torque Value Question: ball joint wedge pin?
What is the torque value for the wedge pin nut that slides through the bottom of the strut?
I see 2 values on the chart below: 32.5 and 15.9
I used the higher value of 32.5.
Anyon?
David E. Clark 01-05-2006 05:02 PM
If it's the castellated nut, like this:
http://forums.pelicanparts.com/uploa...1136509266.jpg
then it's 32.5 otherwise it's 15.9.
IAN 01-05-2006 05:04 PM
It is the nut that secures the wedge pin which attaches the ball joint to the strut.
If I over torqued should I leave alone?
Back it off and re-torque?
Ian
David E. Clark 01-05-2006 05:09 PM
I'd back off and get the torque correct. There is a big difference between the 32.5 and 16!
