cant find bulb for key....
I have been to Radio Shack several times and still cant seem to get the exact light bulb that works in the lighted key (i have figured out using my spare that the bulb has to have a gold/copper tip, bulb's with silver ended tips dont seem to work).
Anyone know where I could find one locally? Seems silly to purchase such a small thing over the net.
1989 911 Coupe - Black on Black
Old 01-07-2006, 05:03 PM
911Atlanta's Avatar
Just saw one here for $5.95: www.*************** -- you can find it hunting around in there.
Dan
'87 911 Carrera - Cabriolet
Old 01-09-2006, 08:32 AM
kang's Avatar
I don't know if this will work for you, but you might consider the LED conversion shown on the second half of this page:
http://p-car.com/diy/key/
Downshift
Old 01-09-2006, 08:34 AM
911Atlanta's Avatar
Kang -- just did the LED conversion you linked above, and it works fantastic ! Thanks
Dan
Old 01-16-2006, 03:02 PM
Southern Class & Sass
Dixie's Avatar
Another vote for the LED conversion here.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-16-2006, 03:49 PM
PRE-H20's Avatar
i am sooooo BUMMED! i just tried the conversion and it DID NOT work for me...
i bought the EXACT bulb, the EXACT batteries, followed the instructions EXACTLY and yet........ no light for me!
can anyone show me the light so to speak?
Old 01-18-2006, 08:37 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
There are very few things you could be doing wrong. It's most likely that you have the leads reversed on the LED. They are polarity sensitive, so the batteries and the LED leads must be in the correct order. Also, be CERTAIN you got the correct LED and battery combination. There are many different LED's which require many different operating voltages. Your battery combination must add up to the correct voltage required by the LED you are using (assuming you are using multiple batteries, in series).
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-19-2006, 12:18 AM
Hey Alex, don't feel bad. I read a thread similar to this one and went to Radio Hack and got the bulb mention above and no go. I'll go back and try again later. I think the battery in the key is 1.5 v and the led requires 3.6 v to work. I tested the battery against the old buld and works fine. I touch both leds on the battery with the led and nothing. I'll let you know if I find something. By the way, are you still doing the runs with Scott, Chris and the OC guys. I'll be grounded for a bit. We just had a 5 week old baby boy. Talk to you soon, I am the guy with the red 930 cab from LA.
Jeff
Old 01-19-2006, 01:55 AM
Seeeu911's Avatar
a site with simple led info
http://wolfstone.halloweenhost.com/HalloweenTech/anemak_MakingLEDEyes.html
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 01-19-2006, 03:07 AM
UFLYICU
ZOA NOM's Avatar
Jeff
Ouch!
Born 5 weeks old??? WTF???
prc-racing.com
Old 01-19-2006, 03:24 AM
Dixie's Avatar
It's most likely that you have the leads reversed...
The easiest way to fix this is simply turn the batteries over. And if you tape the batteries together (at the sides obviously) it will be easier to get everything back into the key case.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-19-2006, 03:55 AM
PRE-H20's Avatar
my very own flamethrower!
zoanas,
ya tell me about it! i know there is VERY little to do wrong! can you imagine how bummed i was that it didnt work! hehehe i guess i should re-think rotating the tires this weekend! hehehe... but ya, i followed the instructions to the T.
i DID get the correct LED and BATTERIES,..... i checked and double checked before i left radioshack.
jeff,
well at the time assumed the info on the thread was correct and bought the items as described..... and yes i plan to make the run with the guys..... and congrats on the bambino! wahhooo!
capt carerra,
thanks for the idea on the batteries,......
and for the GOOD news....
i got my flamethrower working this morning! as i mentioned i followed the directions exactly, "The short post goes to the battery, and the long post gets wrapped securely around the copper pole." which is what i did..... SOOOO i switched it around and WALAAAAA!
Old 01-19-2006, 09:09 AM
UFLYICU
ZOA NOM's Avatar
Awesome. One of the most satisfying mods, in my view. You see it every time you get in the car at night.
prc-racing.com
Old 01-19-2006, 03:16 PM
vash's Avatar
sweet! i am outta door to my local radio shack!!!! mine doesnt work at all.
poof! gone
Old 01-19-2006, 03:45 PM
steve911's Avatar
(Somewhat) silly question -- the key blanks for the lighted key heads are (relatively) ridiculously expensive ($26.25), even from our host. Is it possible to cut down one of these to make it work in the lighted key head?
Here's the blank for the lighted key head:
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 01-19-2006, 10:32 PM
randywebb's Avatar
yes & IIRC there is thread on cutting a new notch
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-19-2006, 10:47 PM
