If you sandblast yourself with silica media, WEAR A RESPIRATOR religiously. You don't want to f#ck with silicosis. Look it up...
This is how I cleaned up my door jamb area. You can see the speed blaster on the ground.http://forums.pelicanparts.com/uploa...1136854171.jpg
I still would cut and replace. Much of the areas are not visible and your amateur welds will not be seen. I'd rather have amateur welds than professional rust. ;) Dennis' work is a great example! :D
George |
| All times are GMT -8. The time now is 06:55 PM. |
