The car is pretty well cleaned up and ready to be wired… I settled on Technica Racewire to supply the harnesses, COP, Motec and PDM. I’ll install it from there and we’ll get it shipped off for professional tuning. Scope below - any thoughts?
Ignition Setup Twin Plug (12x) Denso 4 Way Coil Injectors Injectors (6x) Injector Dynamics ID-1050X Cam Clewett Cam Sensor Crank 964/993 Crankshaft Position Sensor Slytech TMAP Sensor IAT Fuel Pressure Slytech Combo Sensor Engine Temp Factory Porsche 911 Engine Temp Sensor Knock Sensor (x2) Oxygen Sensor (x2) Oil Pressure Oil Temp IACV 3 Bosch IACV Factory Porsche 993 Bosch LSU 4.9 Slytech Combo Sensor |
I’m not in love with this cable throttle assembly as it (a) a little messy looking and (b) will require constant adjustment as the cables stretch and (c) I’m worried about reliability. Since I’m changing out the shrouds I’d like to get this cleaned up now too. Any recommendations on system?http://forums.pelicanparts.com/uploa...1744133140.jpg
http://forums.pelicanparts.com/uploa...1744133140.jpg http://forums.pelicanparts.com/uploa...1744133140.jpg |
The new wire harness, motec, COP etc is getting put together and tested still… I’m cleaning up some odds ends and purchased sheridan fiberglass shroud and tins to install. Also dropped in some titanium intake studs well I’m at it for longevity / looks. Cleaning and replacing other odd bolts etc as well.
http://forums.pelicanparts.com/uploa...1745715684.jpg http://forums.pelicanparts.com/uploa...1745715684.jpg |
Hopefully down to the short stuff here…. Cars loaded and being shipped off for install of the new electrical/motec setup and will roll into tuning of the engine and suspension. Hopefully get everything done this summer (off-season in AZ) so I can get in on the road and track this fall. Will continue to do some misc small projects while this is getting done.http://forums.pelicanparts.com/uploa...1747002570.jpg
http://forums.pelicanparts.com/uploa...1747002570.jpg |
I followed this build back in the day, and it's nice to see that you're continuing with developing it further and making it your own.
Rebuilding the pedal cluster - I’m going to have these parts all powder coated before it’s put back together for longer term rust / brake fluid protection.http://forums.pelicanparts.com/uploa...1747341357.jpg
Updated exhuast is fully mocked up and ready for final adjustments/clean up once the engine is dropped. Just need to remove/adjust the old brackets for final fit. These are going to be LOUD! http://forums.pelicanparts.com/uploa...1748963291.jpg
http://forums.pelicanparts.com/uploa...1748963291.jpg |
Installing now! These Technica Racewire harnesses look amazing.
http://forums.pelicanparts.com/uploa...1752007636.jpg http://forums.pelicanparts.com/uploa...1752007636.jpg http://forums.pelicanparts.com/uploa...1752007636.jpg |
After a long summer break we’re finally getting ready for start up. Transmission cooler is in, new tins, Motec and wiring being wrapped up and putting it back together. Start up is scheduled for this week with the tuner and will post some videos. We’ll get things all put together after startup and then dyno & tune a couple of weeks afterwards.
http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg http://forums.pelicanparts.com/uploa...1759692280.jpg |
| All times are GMT -8. The time now is 05:55 PM. |
