Stressed Member
Need photo of front swaybar bushing
Finally getting around to mounting swaybars on my E after converting to torsion bars in front. The hole for the sway bar was already there underneath all the undercoating, so no drilling involved. Anyone have a photo of the bushing mount on the tub?
-------------------- Garth 70 911E 08 Buell XB12XT |
Question is confusing. I thought all the classic 911's came with torsion bars?
Anyway, are you using SC or Carrera type sway bars up front or a through the body Charlie Bar style??
Tony G 2000 Boxster S |
Stressed Member
For a couple of years the 911E's had a comfort package and came with no torsion bars, just the self leveling hydropnuematic struts. They died years ago, so I converted to torsion bars 22 & 28's. I have a Weltmeister thru body front sway bar and would like to see one mounted at the thru hole.
Look in the tech articles section. There are two articles that might show what you need to se. One is on Fikse wheels and suspension upgrade and the other is 914/911 sway bar installation.
Here's some pics from my '73 RSR clone with the OEM sway bar installed. If you don't see what you're looking for, let me know and I'll go out in the garage and get you a better photo.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Stressed Member
Thanks, perfect. Your wheel well is a bit cleaner than mine...
