Brey Krause Fire Ext. Mount
Ok, i have the Brey K. mount for a standard seat.
I realize the BK bar mounts between the two seat bolts. How does the Fire Ext. mount? Do i need to purchase a 2 strap? What is the least weight that can be mounted on the BK mount? I believe 2.5 is the max. Any help with pictures would be great. thanks jpc
Farmers Automotive 1-800-213-6373 http://www.farmersautomotive.com 1987 928S4,1989 911 25th, 1993 RSA, 1989 944,1988 911 1968 912, 1976 911 S, 1975 914 Engine dyno![]() http://www.youtube.com/watch?v=tJKdvrX_mTI&feature=youtube_gdata_player |
I have the BK mount for my SC. The mounts are a little different for a Carrera but I think the is mounting is the same. I have 5lb FE and I'm sure you could go smaller. The mount has straps incorporated into it so you just strap the FE to it and you're good to go.
Kurt |
Sorry, I just realized I gave you the wrong info. I Think the FE mount came with the FE.Go to a place that specializes in Fire Ext. equipment. It bolts right up to the BK holes.
Kurt |
Bought mine (BK FE mount) a number of years ago, at that time the strap was what came with the FE.
Ray H. 1979 911SC Coupe 2000 986 Last edited by Brillo; 01-15-2006 at 04:38 PM.. |
Thanks, now i need to find a nice halon with the bracket.
cheers, jpc
Here's a link to an S registry thread that also talks about the mount & other options. I bought a halon extinguisher, still mulling over how I wish to mount it.
http://www.early911sregistry.org/forum/showthread.php?t=9137
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Pre Registered
The various BK options are by far the cleanest, least hacked up solution in my opinion. Two frame rail bolts and you're done. Unless you're transporting circus midgets up front, leg clearance isn't an issue as it sits below the passenger's knees.
As noted above, most new bottles come supplied with a strapped bracket: Additionally, BK now also makes a billet, one handle release: Good luck, Tim |
I highly recommend the Halon extinguisher for yourself as well as the owner of the car that you extinguish the fire in. The BK extinguisher bracket is nice however the bracket that comes with the extinguisher works equally as well. I've rubberbanded the safety pin loop to keep the pin from inadvertendly pulling out and discharging, so it requires more of a deliberate tug on it to disengage it.
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
thanks for the postings and pictures.
Mr. Coffey, 5 lbs is bigger than i wanted. Thanks though! jpc
I've got the B/K seat mount for the electric seats if anyone is in need.
40.00 + shipping, coming out of my 993.
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Insert Tag Line HERE.....
how is the electric seat mount different from th standard type?
if it is the same, ill take it.
Marc |
I'll buy it if rattlsnak doesn't want it.
Ben Fegan 1988 Carrera Targa |
