Aluminum or Magnesium
Does anyone know when Porsche started using Magnesium cases? Was it with the 2.7 or before?
With the 2 liter engines in '69.
Marv Evans '69 911E |
Actually, the change from sand-cast aluminum came in the 1968 model year.
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Thanks for responding, I am concerned after hearing many stories about studs pulling out at high RPMs I plan on using this car for an occasional track day. any suggestions?
Case savers or Timeserts ( http://www.timesert.com/ ) can be installed. These devices reinforce the case and have threads on the inside to accomodate the stud.
Mark:
If you some specifics about what you want to do, I'd bet that you will receive some useful suggestions,.......
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Some people have reported that magnesium cases can get so porous that they can actually just leak oil out of the castings. True or false?
Hey Steve,
I am trying to decide what I want to do, I am not sure I want a dedicated track car or something I can drive to the track and have fun with and return home. I will get there soon, I just wanted to start with and engine that won't grenade under stress |
markobrow, should we assume that you have a 2.7? You don't say...
No one ever complains about a 2.7RS motor, and those are built on a mag case! Steve, perhaps you can chime in on your opinion of properly prepped mag case motors? Does the mag case pose any problems? |
I have a 72 with a 2.4L I would like to keep the displacement the same if that's possible
The real key to success with any mag-cased motor are maintaining strict control of oil temps. Keep the oil temperature below 200 degrees F and these are very durable.
Beyond that, case prep is mission-critical and all of them should get case savers and the oil bypass mods. Engines that will see over 7K RPM should be shuffle-pinned. 2.7's and 2.8's should be held to below 7500 to help prevent case cracking.
