oly oly is offline
1985 Carrera Coupe
Is this an upgraded oil cooler on a 1985 3.2?
I don't think this is the original. Am I right? Does anybody know what kind it is and/or about how much they cost?
Old 01-12-2006, 03:01 AM
durn for'ner
livi's Avatar
Mine look very similar and is an original item.
Markus
Resident Fluffer
Carrera '85
Old 01-12-2006, 03:41 AM
Wavey's Avatar
That's just your standard OEM cooler - installed on the car on the production line.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 01-12-2006, 04:15 AM
I concur... looks exactly like my OEM unit on my 85 Carrera.....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-12-2006, 04:59 AM
Bill Verburg's Avatar
What you are looking at is not actually the cooler, but rather the stone shield protecting the cooler
Bill Verburg
Old 01-12-2006, 01:37 PM
This is the cooler
Bill Verburg
Old 01-12-2006, 01:39 PM
MiamiTurbo
Hello, whats the easiest and cheapest way to install a fan on a pre 87 911 that has this cooler but not the fan
wanabe911 owner
1974 914 2156cc project
2005 Lotus Elise Original owner
2002 996TT Tip
Old 01-12-2006, 01:53 PM
I got a SPAL fan (for reliability) with a temp sensor and a relay.
As I recall, the SPAL fan was only able to use three of the four mounting holes onto the framing of the oil cooler.
A better way to go will be to find a factory fan. But I don't think many people will be willing to part with their fan unless they sell the cooler too.
Good luck.
Nick
'85 Carrera
Old 01-12-2006, 02:32 PM
MiamiTurbo
Did you factory cooler already have a port for a temp sensor, or is the temp sensor external? Sorry if this seems like a stupid question, but I could not see any ports on my cooler for a sensor
wanabe911 owner
2002 996TT Tip
Old 01-12-2006, 03:36 PM
Coolers that were not originally equipped with a fan won't have a provision for a temperature switch. That came with the '87 model year. Just run the fan using a manual switch and a relay. Much better, in that you can run the fan whenever you want. The factory temperature switch turned tha fan on at too high a temperature to do much good.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-12-2006, 03:41 PM
MiamiTurbo
Thanks good tip
wanabe911 owner
2002 996TT Tip
Old 01-12-2006, 03:53 PM
I am using a Hayden temperature sensor. This sensor is adjustable from 80 degrees to 250 degress F.
I have it set around 210.
It has a probe that goes into the fins of the cooler and closes a circuit at different temperatures. It runs around $23 at your favorite autoparts store. Some carry them in stock.
Nick
'85 Carrera
Old 01-12-2006, 04:28 PM
oly oly is offline
1985 Carrera Coupe
Thanks for the posts and pictures!
Art
Art
Old 01-18-2006, 01:25 AM
