1982 sc rotors
Where the front rotors drilled on a 1982 sc or did the PO do it?
Sean
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
Mine are stock and not drilled.
'82 SC pewter metallic Time and Relative Dimension(s) in Space |
hmmm
So either he drilled them or they're aftermarket. I guess I better take a look. Thanks.
I'm pretty sure they're vented 11.2 in. in the front and 11.0 in. in the back. Someone else can chime in and correct me on that. That's what's on my '82, in any case.
Got pics of them?
Drilled were not stock issue on Sc's in '82. They should have a manufacturer name somewhere on them. You may have to remove the wheels and check the mounting surface or "hat".
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Retired Member
I understand stock to be solid vented rotors - not drilled or slotted.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Now in 993 land ...
I would be very surprised if the PO drilled the rotors himself or even had it done by a machine shop. They are likely aftermarket rotors that can be had already cross drilled.
George |
Stock 911 and Carrera friont brake '69 thru '83
front front and rear
except thru '75 S and Carrera used S calipers in front instead of A
![]() above is a non stock rotor
Thanks Bill.
Sean
