-   -   HID litronic headlight upgrade (http://forums.pelicanparts.com/porsche-911-technical-forum/261567-hid-litronic-headlight-upgrade.html)
lateapex911 01-24-2006 06:50 PM
I have old US DOT headlights in my 73. I would love to have HID lows and killer 100 watt high beams (with relays, of course), but what conversion kit do I get to house the two bulbs? (H...??) And will the HID bulb match the physical dimensions and light ray pattern the housings, reflectors and glass were designed for?
Any links or clues would be great!
Early_S_Man 01-24-2006 07:03 PM
I'm with Wil ... the HID cartridge isn't aligned with the lens of the H5 assembly ... so it is mostly producing glare, not a usable pattern for the high beam. Kludge, but with a nice touch ... the kit gives you four awful splice connectors that a 911 owner should be punished for using on his/her car's electrical system!
Won 01-30-2006 12:40 AM
Not for H5, but I missed that part earlier and thought about something for H4, and found a thread with exact same idea: H1 clear lens and projectors
And if the clear lens is too boring, you could mount the projector close to the lens and sandblast the unused clear part, a la 993 litronic
http://departstop.com/images/993lit.jpg
Yellowbird RS 01-30-2006 09:26 AM
Originally posted by GaryR
That worked for me!
At least they come from ********** and not some guy in a van somewhere. My guess is they will work as advertised, and for $300 it's a pretty darn good deal! In the past you had to convert H5's to H4's, THEN put a Xenon conversion kit in..
YellowbirdRS - where is the kit you show for H4's sold? How can an HID bulb be added without any ballast?
here it is the Bi-Xenon upgrade
and this is the Xenon Low/halo HI
