Has anybody tried this setup currently advertised on e-bay?
It is supposedly specifically designed for Porsche. I wonder if anybody has installed/tested one. Thanks!
Dietmar 1987 911 Carrera 2008 RS 60 Spyder |
I got this from your link:
This listing (# 8031130335) has been removed or is no longer available. Please make sure you entered the right item number.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
try this link:
or search for "Porsche 911 H5 H-5 Xenon / HID / LITRONIC Conversion", they have several auctions for these open.
GRRRRRRRRRR!!!!! The e-bay link does not work for any of the auctions. I am doing something wrong!
type or paste: Porsche 911 H5 H-5 Xenon / HID / LITRONIC Conversion in the e-bay search field. Sorry, just can't get it to work otherwise.
Got it that time,
No experience with these things, just opinions. I would think that they are better than the "blue bulbs" that sucker so many in, but I wonder if a halogen mirror has a different shape than a Zenon one. Physics would say no, but that was many years and beers ago.
Looks like they're fitting an HID bulb into the factory H5 headlight and driving it with a balast.
I'd be curious how the standard encolsure handles the heat. Also, for optimal results, the lens should be designed for HID. That said some like the results anyway.
Warren & Ron, may you rest in Peace. |
UFLYICU
Lower power consumption/dissipation would indicate it will be less likely to burn the plastic parts than the stock halogen bulb. They claim it only uses 35 watts of power.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Wer bremst verliert
I installed these in my 993, they worked great. I did a DIY install page too, posted over on Rennlist...here's the link...
http://forums.rennlist.com/rennforums/showthread.php?t=180644&highlight=HID
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Diss Member
Just want to try an experiment to see if I can alter an ebay link so it will work...
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I think the lack of low beam/ high beam....even although it's said not to be needed...is bad.
How do you satisfy vehicle inspections to demonstrate a hi/lo beam function ?? Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
UFLYICU
Wire your Cibies to come on with the highs, Wil.
One pal of me installed one from ebay's into a 2004 Turbo S Volkswagen Bettle and works great.!!!
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Wer bremst verliert
Wil,
You don't lose your highg beams at all. You wire the HID into your low beams (which is what you use most often in the burbs anyway) and keep you high beams just as they were. If you are installing into an earlier car you should use relays and can then up your highs to 100w+
H4 Hi/Lo HID Bulb
@ Product Features: Converts only Low Beam to HID, high beam will be replaced with a halogen bulb. No cutting and re-wiring required for entire installation. 35W. Xenon Gas Filled HID bulbs. No Filament 5000K ~ 10000K color temperature. More light output Longer life Super-White light and more intensity of lighting. Easy to installation (20 minutes for a beginner)
X/A |
This looks interesting...
http://www.mycarr.com/cgi-bin/getprod?home=mycarrauto&prodid=p002&lang= Brad
'78 911 SC '61 Mercedes 220b '74 Westy 2.0 |
Banned but not out, yet..
I just installed HIDs in my Audi tonight. Single 'bulb' for high and low beam and they really work. I paid $360 including shipping. They are so bright on low beam, I am a little afraid of how many flashes I will get tomorrow AM - but what a difference!
An air cooled refrigerator. Mein Teil |
But... the two bulbs are no longer co-axial.....which was the original design assumption as to how the glass flutes were cut.... I see this as a kludge, until I learn more...
Wil
At least they come from ********** and not some guy in a van somewhere. My guess is they will work as advertised, and for $300 it's a pretty darn good deal! In the past you had to convert H5's to H4's, THEN put a Xenon conversion kit in.. YellowbirdRS - where is the kit you show for H4's sold? How can an HID bulb be added without any ballast?
Gary R. Last edited by GaryR; 01-19-2006 at 06:52 AM.. |
For a single 'bulb/element' for both hi/low beam - search using 'Bi-xeon'. My Audi has such lousy OEM DOT lights, that I really don't know how effect the hi-beams actually are, but the low beams are SIGNIFICANTLY brighter - almost to the point of being too bright for oncoming drivers, so I pointed them down a bit - but no one has flashed yet.
Anyone have experience with H1 conversion kits?
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
