what is this thing
More to the point how do you use this thing to adjust valves?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Mount a dial inicator and measure the 0.004" free travel.
John Adams 1980 ROW 911SC |
I know there are people who use them to adjust valve clearances, but the intended purpose of P207 is to check cam timing by mounting a dial indicator to the spring retainer with at least 0.5" of preload at TDC on the firing stroke, then turn the engine over to TDC overlap on the exhaust stroke. The measured lift value at overlap is then compared to the spec book or cam grinders spec.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
