H&R springs for 94' Carrera 4
Anyone experience these springs? Too low, too stiff? I just want to lower my Widebody to take the space out between the tires and fender! Any good shops for alignment in L.A. O/C?
Insert Tag Line HERE.....
If you're looking to lower your ride, then these work fine. If you're looking to lower your ride and keep a soft suspension, that wont happen. These will make it stiffer, and make it look a lot better.
Marc |
I have H&R's on my '03 M3, they are very stiff, stiffer than Eibach...Rattlsnak is right.
As far as alignment shops in L.A. try Johnson's Alignment in Torrance (Hawthorne Blvd. at 190th). They are experts with 911 track cars, one of the owners/brothers has been racing 911's for years. They may be able to recommend springs for you before you spend the bucks.
Eric 1973 911t 'RS' 1970 Datsun 510 (vintage racer) |
Thanks for the information. It's nice to work off of others' experiences.
Randy 73.5 911 T 97' C2S 06' C2S |
