cycling has-been
77 930 euro exhaust vs us
I bought an oem 'euro' exhaust at a swap meet to get rid of my thermal reactors. When I look at the 2 assemblies side by side ( original is still on the car), they look a lot different.
Anyone know what the brass canister that runs from the left side heat exchange bung hole towards the front of the motor is? (US version) Does system offer less back pressure with the 3" inlet vs the 2 into 1 y joint on the original? Does the forced hot air (for heat) match up from the top side of the motor? thanks Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
the brass (?) canister thingee is, in fact, the EGR filter. Can I run okay without that?
thanks Bill K
Crotchety Old Bastard
The Euro system is not only vastly superior to the US but is manditory if any mods done to the engine are to be effective.
If you do not need the smog stuff you can ditch the entire US exhaust including the air pump and spider. You'll need a Carrera style oil line and maybe a bit of hot air hose rennovation and you're in business.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
cycling has-been
thanks rarly. pardon my ignorance, but what's the spider?
Yes I am smog exempt in NJ, and air pump is gone. Also, what is Carrera style oil line? I though I would have had one already, the car being Carerra family. Bill K
Spider is the air injection lines that go to each cylinder under the engine.
Carrera oil line is used due to the similarity in the heat exchanger configurations of the Carrera and 930 Euro. The US line will hit the Euro exchangers. I have some pictures on another computer. I'll try to post them for you.
cycling has-been
RarlyL8
can you id the oil line I will be needing? I'm guessing the crossing one by the muffler. Happen to have a pn? Will I also need any of the flex lines? thanks Bill K (hyjacked photo from turbo board)
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 01-23-2006 at 11:09 AM.. |
