1982 sc rotors
Where the front rotors drilled on a 1982 sc or did the PO do it?
Sean
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 01-19-2006, 05:49 PM
JR_NYC's Avatar
Mine are stock and not drilled.
'82 SC pewter metallic
Time and Relative Dimension(s) in Space
Old 01-19-2006, 05:51 PM
hmmm
So either he drilled them or they're aftermarket. I guess I better take a look.
Thanks.
Sean
NASA GTS2
Old 01-19-2006, 05:56 PM
JR_NYC's Avatar
I'm pretty sure they're vented 11.2 in. in the front and 11.0 in. in the back. Someone else can chime in and correct me on that. That's what's on my '82, in any case.
Old 01-19-2006, 06:03 PM
Oh Haha's Avatar
Got pics of them?
Drilled were not stock issue on Sc's in '82. They should have a manufacturer name somewhere on them. You may have to remove the wheels and check the mounting surface or "hat".
Pacific Blue
Wayne
Old 01-19-2006, 07:20 PM
Retired Member
Charlie V's Avatar
I understand stock to be solid vented rotors - not drilled or slotted.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 01-19-2006, 08:43 PM
Now in 993 land ...
aigel's Avatar
I would be very surprised if the PO drilled the rotors himself or even had it done by a machine shop. They are likely aftermarket rotors that can be had already cross drilled.
George
81 SC (sold)
Old 01-20-2006, 12:39 AM
Bill Verburg's Avatar
Stock 911 and Carrera friont brake '69 thru '83
front
front and rear
Bill Verburg
Old 01-20-2006, 01:37 PM
except thru '75 S and Carrera used S calipers in front instead of A
above is a non stock rotor
Bill Verburg
Old 01-20-2006, 01:41 PM
Thanks Bill.
Sean
Sean
NASA GTS2
Old 01-20-2006, 05:24 PM
