-   -   911T 1971 restore process (http://forums.pelicanparts.com/porsche-911-technical-forum/262029-911t-1971-restore-process.html)
Mateusz 01-20-2006 04:05 PM
that is how she looked like in september
http://forums.pelicanparts.com/uploa...1137805105.jpg
then in october the work started in my little garage
http://forums.pelicanparts.com/uploads6/11137805475.jpg
Mateusz 01-20-2006 04:18 PM
i'm not going to hide that the layer was thick
http://forums.pelicanparts.com/uploads6/21137805922.jpg
http://forums.pelicanparts.com/uploads6/31137806152.jpg
now i guess she lost about 30kg ;)
http://forums.pelicanparts.com/uploads6/41137806247.jpg
Mateusz 01-20-2006 04:28 PM
http://forums.pelicanparts.com/uploads6/51137806448.jpg
and next stage....
http://forums.pelicanparts.com/uploads6/61137806781.jpg
http://forums.pelicanparts.com/uploads6/71137806807.jpg
http://forums.pelicanparts.com/uploads6/81137806824.jpg
Mateusz 01-20-2006 04:34 PM
getting ready for painting.....
http://forums.pelicanparts.com/uploa...1137807264.jpg
http://forums.pelicanparts.com/uploa...1137807279.jpg
Bobboloo 01-20-2006 04:40 PM
Excellent. I see the original color was Metallic Gold. What color are you repainting the car?
MichiganMat 01-20-2006 04:40 PM
wow, kickass. Nice work my friend, nice work.
Mateusz 01-20-2006 04:41 PM
http://forums.pelicanparts.com/uploa...1137807430.jpg
now the colourant undercoat
http://forums.pelicanparts.com/uploa...1137807648.jpg http://forums.pelicanparts.com/uploa...1137807666.jpg
http://forums.pelicanparts.com/uploa...1137807684.jpg
Mateusz 01-20-2006 04:49 PM
and next stage completed
http://forums.pelicanparts.com/uploa...1137808091.jpg
http://forums.pelicanparts.com/uploa...1137808123.jpg
http://forums.pelicanparts.com/uploa...1137808146.jpg
Grady Clay 01-20-2006 04:51 PM
Welcome to the Forum. You will find lots of help here.
You now have the serious responsibility to get the “T” back on the road. Judging by your pictures, you have a lot of work ahead of you. The more questions you post on the Forum, the better we can help.
At the bottom-rear of the rear window, inside that double panel there is a sound-proof “gasket”. It tends to absorb moisture and should be removed. When dry and warm, coat the inside with a rust preventative. If you have your 911 on a rotisserie, also apply this with the chassis upside down.
After you remove the tail light assemblies, pay particular attention to the corners toward the inside rear. You want to make sure there isn’t any rust.
When you have the engine & transmission out, I recommend you disassemble the rear suspension and inspect the inside of the torsion bar tube. Probably this is the most critical part of the 911. Clean the torsion bar splines and preserve the interior of the tube. Do a search on rust tube torsion bar and more.
It is your responsibility to do this correctly. You will be rewarded with many years of fun and satisfaction and have a well preserved and valuable early 911.
Best,
Grady
Mateusz 01-20-2006 04:52 PM
i did't paint it gold cuz as rightly Tomy said it would look like deawoo (if you know what it is i hope you don't:) ) anyway we have too much of these cars here in Poland :)
Jays72T 01-20-2006 04:55 PM
Nice work!!
Mateusz 01-21-2006 02:51 AM
Grady Clay
thanks for a welcome and pieces of advice very grateful 4 it!!!!
Jason Cullen 01-21-2006 02:57 AM
Bara Bing - Looks wonderful!
72 four door 01-21-2006 04:52 AM
Fantastic job! Good thing you caught that rust and did it before it got to bad. That paint job looks to be top notch!
Zeke 01-21-2006 07:47 AM
Nice work! When I saw the new inner fender support, I thought, ohh ooh. That's a tough one to line up. But, the fenders and doors image perfectly in the pics.
And, wow!!, a tiled wash bay before the downdraft spray booth. That is first rate. I'd go back to painting cars if I had a set up that nice. I've never seen such a nice facility.
kevin993 01-21-2006 07:51 AM
Looks great! Thanks for sharing the pics. Looks like you've done a nice job and come a long way. Look foward to seeing the finished product. Good luck...
dmcummins 01-21-2006 08:12 AM
Very nice. Keep us posted.
Mateusz 01-21-2006 09:51 AM
http://forums.pelicanparts.com/uploa...1137869481.jpg
bigchillcar 01-21-2006 03:03 PM
beautiful! looks like 'peru red'..am i close? :)
ryan
Mateusz 01-22-2006 10:38 AM
hi
actually its indischrot
