Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
If everyone PMs wayne (or starts a post about it...maybe I will) we could get the ball rolling on a paint and bodywork forum.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-20-2007, 02:14 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Originally posted by rw7810
I mentioned this to Wayne some time ago and he generally agreed, but has made the additon yet......
I agree, there are enough dead thread areas and this subject would be really beneficial ,, Wayne???
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-20-2007, 06:48 AM
Rennch on YouTube
rennch's Avatar
Ok, I'll start a thread. make sure everyone hits it and puts in their 2 cents.
Michael O'Neal -
Old 05-20-2007, 09:11 AM
Rennch on YouTube
rennch's Avatar
Ok, here's the post. Subscribe away:
We need an official Paint and Bodywork subforum. All in favor, say aye!
Michael O'Neal -
Old 05-20-2007, 09:19 AM
Rennch on YouTube
rennch's Avatar
Freddy (Or anyone who knows the answer), I had a couple questions for you from this thread:
1. Is POR-15 Metal Ready the equivalent of your DX 579? () I have a gallon of that already on the shelf.
2. Should I do any preliminary body work before putting on the Epoxy Primer?
3. Does the Epoxy Primer need to be applied in a professional way like paint and clear does, or can I do it in the driveway or in the garage?
4. On that note, does the Epoxy primer need to be from the same manufacturer as whatever paint/clear I use?
Thanks!
Michael O'Neal -
Old 05-24-2007, 12:30 AM
rw7810's Avatar
I think I can answer your questions based on my project and research.
1. Metal ready is an acid based rust converter like the DX579. See comment 4.
2. This is a real debatable area, but most pro-body men will recommend filler directly on fresh metal. the epoxy manufactures say it doesn't matter. This forum has a great debate on the issue: http://www.autobodystore.com/forum/index.php
3. The epoxy and primer filler can just be done in the driveway, etc. no need for a homemade booth, etc.
4. This is probably your most important question. Using different manufacturers/vendors can and will cause incompatibility problems. Best to stay with one, PPG, Dupont, POR15, etc.
Robert Williams
70' 911T
Old 05-24-2007, 08:04 AM
Rennch on YouTube
rennch's Avatar
Bob,
Thanks for all the info...I guess I'll have to pick up my paint, and work backwards from there in terms of my metal prep.
In terms of the bondo on the bare metal, if watching "American Hot Rod" serves me well, they typically blast the car then get the epoxy primer on it right away, before the body work.
Michael O'Neal -
Old 05-24-2007, 08:33 AM
safe's Avatar
Does the epoxy primer seal any remaining rust like POR-15 is supposed to do?
Magnus
Old 05-24-2007, 08:46 AM
Bill is Dead.
cashflyer's Avatar
At my shop, we put the epoxy primer directly to the bare metal (after acid etch). This "seals" the metal.
I have not evaluated POR-15, but it has been my experience that untreated rust will continue to rust. If you diligently remove all rust and closely follow the directions for acid etching and conversion coating (the process of the two chemical treatments described on page 1), then follow with an epoxy primer... you should be effectively sealed against the elements and against further rust problems.
If you're doing an area like a door jamb where you only have access to one side of the rusted metal... well, that other side will just keep rusting.
Advice is based on my personal experience... and I'm no pro.
Old 05-24-2007, 08:51 AM
Rennch on YouTube
rennch's Avatar
Have you guys heard of the POR 15 Metal Ready leaving some kind of oily film? A very experienced Pelicanite told me that and made me wary of using it.
Michael O'Neal -
Old 06-11-2007, 09:33 PM
rw7810's Avatar
I've used it quite a bit and never had an oily issue. Preparation of the metal per POR 15 instructions is imperative
Robert Williams
70' 911T
Old 06-12-2007, 09:26 AM
fhernand's Avatar
My last rhread on final sanding and painting is out. Hope this help. Freddie
VINTAGE SPORTSCAR RESTORATIONS
www.vsrestorations.com
freddie@vsrestorations.com
Freddie Hernandez
(541) 535-3304
Old 08-04-2007, 08:16 PM
Rennch on YouTube
rennch's Avatar
Ruh Row...
Freddie,
My car has been sitting in bare metal for a while now (a few months) in Colorado (dry climate). It was getting a little film of surface rust, especially over my welds. Today, after reading this thread again, I decided to hit the whole body with POR 15 Metal Ready, which is a zinc converter as well.
These are the results. It looks like the color of "runny rust". Did I do something wrong, or is that the zinc primer?
Should I hit it again with water and a scratch pad?
Michael O'Neal -
Old 09-03-2007, 02:52 PM
fhernand's Avatar
Nice job on the stripping. The rust looking stuff is actually Zinc Phosphate. It's actually a good thing to be able to see this film. This means that it is itching the metal. Do try to get some primer on this metal. . . even in Colorado. Good Luck.
Freddie Hernandez
(541) 535-3304
Old 09-03-2007, 03:00 PM
TxSquash's Avatar
Before I Prime Question.
Freddie,... I've followed your metal condition instructions, using DX579 & DX520. They have left a powdery film on the panel ( I think this is what it's suppose to do, a form of galvinizing). My question, do I remove this film before I epoxy prime? Do I wash the panel, do I wipe it down with wax and grease remover? Or do I just shoot over the powdery film?
Thanks, .. a great instruction series.
Doug
Doug
78'SC Targa
uno owner... moi'
Old 05-02-2008, 04:54 PM
fhernand's Avatar
Doug, you might have left the itching on the panels a little too long before the rinse. No worries though. Wipe with grease and wax remover. Wipe wet and dry right behind the wet rag. Make sure that the rag you use to dry does not leave any bits of lent behind. If it does, use a tack rag right before your primer. I'm glad the suggestions are helping you. Good Luck Doug.
Freddie Hernandez
(541) 535-3304
Old 05-02-2008, 05:04 PM
TxSquash's Avatar
Freddie,.. thanks alot for the reply. Onward to the epoxy primer!
Doug
Doug
78'SC Targa
uno owner... moi'
Old 05-02-2008, 10:58 PM
Freddie,
Excellent series - I intend to put to good use soon!
I am planning on having my parts media blasted vs chemical strip. On some parts such as hood and fenders, I intend to also lightly blast undersides to clean them all off of paint but leave the good portions of the undercoating. I am assuming then I would move right into using the PPG DX 579 Metal cleaner followed by the DX 520 metal conditioner before priming. Do you see any issue with that? How quickly do I need to get the cleaner/conditioner primer all completed after the media blasting? Should this proces also be used on the undersides where bare metal get's exposed? Will the cleaner/conditioner be an issue on left-over undercoating? Thanks for your help,
Jeff
Old 10-29-2008, 01:53 AM
Champagne on Beer Budget
HelmetHead's Avatar
Fredie,
First let me say that your paint and body work threads are great sources of information and have helped me to overcome some of my fears of doing my own paint work.
My car is currently in a similar situation to Emptyos'...I soda blasted my tub and its been sitting for months. I have the 579 and 520 cleaner/conditioners and my primers ready to go, but I have one major concern with starting on the tub.... Since I will cleaning and conditioning sections of the car, like the interior/dash then priming it and moving on to another section...will the 579 and or 520 cause any damage to new Epoxy primers if it gets on to it? Obviously I will follow the data sheets on cure times and make sure i've got a nice hard coating before I move on to other areas...but I can just see myself getting the entire underside of the car sealed/primered and then I wash off the 579/520 on a inner fender area for example and discover that its discolored the epoxied areas I just completed or something wierd like that.
Any experiences with this or am I in left field?
Thanks in advance,
Einar
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 10-29-2008, 06:54 AM
fhernand's Avatar
Elinar, you will be safe so as long as you let the epoxy cure well you will be fine. Remember that water on the condition/cleaner quickly cuts the chemical reaction on the metal. I have made it a habit of rinsing twice with some soapy water. Do not mistaken the film left by the condition/cleaner as a bad film. It will leave a film even after you rinse. Sound like a very nice project you got going there. Best wishes.
Jeff, the sooner you clean, condition and prime the metal spots, the better this will be for your bare metal spots. Of course, there are occasions where I have left bare metal sit for a day or two but always enclosed. I epoxy will be fine over the undercoats so as long the undercoating is clean.
Freddie Hernandez
(541) 535-3304
Old 10-29-2008, 10:29 AM
