91 C2 will only run on one coil
my car started acting up the other day and got progressively worse untill it wont run at all.
some experimentation has yielded the following strange results
it runs smoothly if i drive the secondary distributor with the secondary coil. it runs albiet roughly when i drive the primary dist with the secondary coil
it runs smoothly when i drive the secondary dist with the primary coil. it wont start when i drive the primary dist with the primary coil
it wont start in the normal 2 dist/ 2 coil condition. (it tries to start but doesn't)
if i drive the coils with each others drivers, nothing happens in any condition....so there is a difference at least in the way the coils are driven
who really knows how this system works???
Old 01-22-2006, 06:39 PM
CBRacerX's Avatar
Simple question, but is the belt broken? I realize the symptoms don't reflect this, unless you have the primary and secondary confused.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-22-2006, 07:49 PM
no the belt's good
Old 01-22-2006, 08:40 PM
