Bolt Removal
What is the best way to remove a bolt whose head is starting to round? There is a good amount of rust on it and I have used heat, but I do not want to strip the head completely.
Thanks All.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
in my experience, the first thing to try is to put away the 12 pt socket and try a 6 pt.
poof! gone |
Oh, forgot to add, it is in a tight place. No room for impact or socket.
I agree, 12 pt certainly would not help. Thanks
If that doesn't work, you might try cutting a 'slot' in the top of the bolt (with a dremel, etc) and try a screwdriver, or if worse comes to worse, cut off the bolt head, or drill it (depending on how it's attached). I had a bear of a time with some rusty exhaust bolts and ended up cutting most of them off.
6 point box wrench. and sears has a new product< a "bolt out" based on a ratcheting box wrench.
poof! gone |
Soak it in penetrating oil (liquid wrench...) for at least 24 hours. The longer the better.
Regards, Guenter 73.5 911T, mod |
Liquid wrench..and such ( WD-40) is totally worthless and useless...
Only 3 products work ( IMHO....) - Kroil - PB Blaster - Wurth "Rost-Off!" Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I will continue with the PB, but am concerned with rounding the head.
PB blaster does work well as I soaked down my exhaust studs for a week before I tried removing them. Viola, no problems. And initally they wouldn't move. Thanks for the ideas, I guess I am off to Sears.
Unregistered
Sometimes you can find an SAE wrench that fits a metric head tighter and gets a better bite if the rust has made the head undersized.
I agree with the above, Kroil is the kind. |
UFLYICU
If you can get a bite on the bolt, you can use an air hammer against the wrench while you push.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Detached Member
The Sears "bolt-out" sockets work very well. Their ratchet wrenches may work well too.
Hugh |
Autodidactic user
I've had great luck with the "Craftsman 10 pc. Damaged Bolt/Nut Remover Set":
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
If you dont want to spend the money, I have removed many a stripped bolt with a good soaking, a set of vice grips and heat. Of course the fastener will have to be replaced.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
