heater cntrl assembly on e-brake 86 and higher
what does this item control????
Old 01-27-2006, 01:42 PM
Jeff Alton's Avatar
The temp
www.turn3autosport.com
Old 01-27-2006, 01:50 PM
ha ha.......................
what exactly front motors rear motors
what???
Old 01-27-2006, 02:31 PM
Used Up User
imcarthur's Avatar
This might explain:
I had to link outside Pelican because of the current picture loading problem.
Ian
'87 Carrera Cab
Old 01-27-2006, 02:38 PM
Jeff Alton's Avatar
Sorry, I realize my short reply made me sound like an a$$! That pick above is a great explanation. The controller will turn on the engine room fan and control the flapper boxes and control the footwell blower motor speeds. It uses intake and cabin sensors to determine how much of each it will control.
Cheers
Old 01-27-2006, 06:37 PM
I purchased a later e-brake heater unit to
#1to clean up the "look"
#2to maybe buy the the under dash fans and boost the way the car heats up.
i was wondering were thos wires under the unit went to if they went to the fans under the dash.
Old 01-29-2006, 07:53 PM
LOL..ooh your the one that I lost that item to!
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 01-30-2006, 07:18 AM
favrok01,
You'll need a lot more stuff to make that work on your car, if it didn't originally come with one. Two different temp sensors, a different cable to the heater valves, lot's of wiring....I type too slow to list it all.
Good luck,
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-30-2006, 07:33 AM
from Mysterytrain
sorry but you did run the damn price up didnt you?
Old 01-30-2006, 09:12 AM
javadog listed problems
anybody have a wiring schematic or an idea were the wires go for the knob on the console???
Old 01-30-2006, 09:14 AM
Ok, I'll help you wire it since I'm feeling really guilty about running the price up. You should have called me I would have backed off. Anyway, the information I'm offering is priceless. I'm not sure what year car you have but for the 78SC it goes like this. The heater levers between the seats turn on the rear blower and that pushes warmed air into the cabin. I removed the rear blower in my SC and installed two footwell blowers when I back dated my exhaust with SSI's. The carrera's came with the footwell blowers installed. Some cars came with manual heat some with the autoheat system. Tell us what year car you have and where the blowers are and I will get into it in detail.
Peace, Ron
www.ronorlando.net
Old 01-30-2006, 10:56 AM
ok i have a 83 with the blower in the rear i have since done maintanance to the heater control valves and made sure they close all the way i have also installed new hoses so there are not any leaks.
i have small vents on both sides and am planing to install the later larger vents with the footwell blowers to work in tandom with the rear blower.
any ideas??
Old 01-30-2006, 11:28 AM
Jeff Alton's Avatar
If anyone needs a controller, I have one available. Just click on the email tag and emai me!
Cheers
Old 01-30-2006, 11:33 AM
Ok, so its an SC. I guess you could use the speed switch on the console to control the rear blower speeds but I think it would be a waste of time. I have found that just using the footwells makes the heating system function better then it ever did with the rear blower. You also might want to re-think hacking the dash to install larger side vents I found with the footwell blowers and additional plumbing to the side vents that they work fine for heat.
Here are some pictures of the parts:
The last picture shows the fitting that is attached to the footwell blowers that directs the heated air into the trunk and also to the side vents via the small diameter duct. If you have air conditioning then you will also need the wye connectors parts 13 and 18. To get the speed switch to work you will need to buy some additional wiring harnesses, the resistor and a relay. Shown in the second drawing.
This is an electrical drawing of the basic SC single blower system:
This is the basic circuit you will need to install to get the footwell blowers and the speed switch to operate factory style. Everything from pin 87 on the rear blower relay is new wiring.
The factory used the resistor pack to control the first two speeds. The high speed was controlled by the aux relay in the drawing in an effort to protect the switch contacts from burning up. Although this drawing doesn't show it, its a good idea to use inline fuses at each blower and to wire the speed switch so that the blowers operate at a slow speed (same as position 1) when they are in the '0' or off position to help save the bearings in the blowers. On/Off is actually controlled by raising the red levers.The factory also did this.
When I installed the footwell blowers in my SC I modified the original circuit because I felt that the high speed was just too fast and made too much noise. I came up with a simple three resistor setup that eliminated the need for the aux relay circuit. I used 2 -100 watt 1 ohm and 1 -100 watt 2.2 ohm resistors. The resistors are mounted on an aluminum plate and are tucked behind the passenger side footwell blower. My blower speed switch is an A/C blower speed switch that I bought and is mounted on a panel in my center console under the OEM A/C controls. The wiring color code of my switch does not reflect the wiring of the factory heater console switch.
Here is my simple circuit:
Here is a picture of the footwell blower in the cavity the resistors are the gold colored things in the back:
Here is a shot with the blower removed, showing two of the resistors on the front of the plate. There is one mounted on the backside of the plate:
And another shot of the wye connector going to the side vent:
Lots of info here:
Help! Does anyone understand the footwell blower circuit?
And here:
Footwell blower thread closed?
Peace, Ron
www.ronorlando.net
Old 01-30-2006, 01:22 PM
Great thread. Thank you all.
87 blk coupe
Old 01-30-2006, 01:28 PM
Does anyone have the rubber hose that directs air from the floor to the inlet of the footwell blower? It is #5 in the diagrams above and you can see it in several photos as well.
Thanks, 337
Old 01-30-2006, 02:43 PM
I would have to say that Mysterytrain has given the best explanation and direction anyone could ask for. I got realy luck in you replying to my topic and sorry to take that item in ebay from you
Old 01-30-2006, 08:00 PM
