Question Ehaust studs and gaskets-replace?
Does one typically replace all of the exhaust studs and gaskets when re-installing/swapping the heat exchangers or do you use the old stuff? Typically I replace old hardware with new oem, but I'm not so sure about backing out all those studs.TIA
Old 01-28-2006, 08:39 AM
Send a message via ICQ to fly944
I wouldnt mess with the studs unless you have to. If you break some off you will not have fun. Gaskets should always be replaced.
Old 01-28-2006, 08:49 AM
