How to remove clutch pedal shaft??!!
It turns out, the part of the clutch pedal shaft where the clutch cable hooks onto has broken. So the clutch cable has no where to connect to anymore.
Can i remove the shaft (34 in the diagram) without removing the pedal cluster? If not, once the cluster is out, how do i take out the shaft? And its hard because my car is RHD and all the diagrams are reversed! lol Thanks for your help
_____________________ '73 RSR Interpretation ---------------------------------- |
the pedal cluster has to come out before it can be disassembled.
Impossible to do in the car. It's time for a proper cluster rebuild. Remove pedal cluster, drive out pin 29. and the whole thing comes apart.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
ok, thanks alot!
