Front Valence Removal Help
Trying to remove my front valence and not having any success. I removed 2 sheet metal screws on each side which connected to the fenders. I removed a bolt on each side which connected to a bracket support. There is something holding it on in the middle, but I can't seem to get any access to find. Any help would be appreciated.
TIA, John
1985.5 944 GTS |
Sultan of Sawzall
inside front of trunk? low & in the center?
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Are you working with the bumper on or have you removed the bumper already?
88 Carrera cpe mostly stock |
There are two screws that install throught the front sheet metal panel in the trunk and attach to two nut inserts placed in holes in the brackets that are attached to the backside of the front valence. They are on either side of the license plate area. They will have regular washers on them plus a special sealing washer to keep water out of the trunk. They may be hard to see at first, as one tends to get hidden behing the wiring and whatnot that is attached to the inside of the front bulkhead.
JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame |
I found the inside screws, thanks. I'm converting the fog lights to brake ducts. I'llpost the pictures and info when I'm done.
John
1985.5 944 GTS |
