-   -   911/930 engine serial number (http://forums.pelicanparts.com/porsche-911-technical-forum/263499-911-930-engine-serial-number.html)
ejscott 01-29-2006 08:11 AM
Hello,
I would appreciate it if someone could tell me where the serial number is located on 911/930 engines and how to read the number IE: year, displacement, etc.
Thank you!!
EJ
javadog 01-29-2006 08:14 AM
EJ,
Look the the right of the fan, on the engine case. There are two numbers. The type number will tell you which engine you have (eg. 930/03) and the serial number will identify the year made. You have to have both and a decent book to look up the information. Report back and we'll let you know what you have.
JR
ejscott 01-29-2006 08:38 AM
JR,
Thank you for the reply and the offer to help.
I have looked and I can't find the numbers. The engine is in the car and complete. Can the numbers be seen when the engine is in the car?
Please advise and thanks again.
EJ
javadog 01-29-2006 08:55 AM
EJ the numbers are easily visible with the engine in the car. Look to the right of the fan, towards the bottom where it sits in the engine case. There is a vertical surface with one number and a horizontal surface with the other. Both surfaces are part of the engine case. Use a flashlight.
JR
ejscott 01-29-2006 09:22 AM
JR,
Wow....I must be a real lamo. I can't find them. I have taken a picture of the area I think I'm supposed to be looking in. Do you have an email address I can send this picture to you at?
Thanks for all your help!
EJ
Seeeu911 01-29-2006 09:38 AM
Look at this thread http://forums.pelicanparts.com/porsche-911-technical-forum/263379-911-engine-numbers.html and this site. http://www.elferhelfer.com its in german but very helpfull.
Thanks MARTIN AIDE
http://forums.pelicanparts.com/uploa...1138556312.jpg
mmastro 01-29-2006 09:40 AM
Go to this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/251933-engine-serial-number.html
Cheers,
CliffBrown 01-29-2006 12:04 PM
If you have an AC compressor it might be difficult without knowing where to look.
Look above the oil pressure sender at the base of the fan support for the serial number. Using a flashlight in a darkened garage can help focus your examination to that small area. The numbers are stamped not raised.
