jpahemi's Avatar
Harry:
What keeps the foglights from coming on without the low beams? What I would like is to pull the fog dash switch and have them come on without pulling the headlight switch. Am I missing something; is it a matter of changing the wire layout on the trunk fuse panel?
Thanks,
j.p.
Old 01-31-2006, 06:22 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
The supply voltage for the fogs comes from the headlight switch. In order to run the fogs independently, you need to provide the source voltage from some other source.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-31-2006, 06:39 PM
HarryD's Avatar
Originally posted by jpahemi
Harry:
Thanks,
j.p.
j.p.,
In my wiring, I am powering the fog lights by a separate circuit that does not come through the headlamp switch. In my case, I do not have the factory switch so I created my own.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-31-2006, 07:37 PM
jpahemi's Avatar
Harry:
Could you give me a diagram, so I could adapt mine to work similar.
j.p.
Old 05-29-2006, 07:17 PM
HarryD's Avatar
Harry:
j.p.
Hi JP,
The drawing is shown on the first page (http://forums.pelicanparts.com/uploads7/Relay+Wiring1138682812.jpg). Is there something else you are looking for?
Harry
2020 MB E350 4Matic
Old 05-29-2006, 07:46 PM
jpahemi's Avatar
Forgot to look, thanks.
j.p.
Old 05-29-2006, 07:51 PM
HarryD's Avatar
j.p.
No biggie. I do stuff like that all the time.
Harry
2020 MB E350 4Matic
Old 05-29-2006, 08:07 PM
Banned
Gosh darn impressive
Geez... looks like you could package this post and defend it for a doctoral presentation to the electrical engineering faculty at CalTech. Very nice !
Old 05-07-2009, 06:35 AM
scarceller's Avatar
Has anyone thought of using hi-powered PNP transistors as relays? These would last nearly forever compared to switch contacts. Only downside is you'd have .3v or so loss across the transistor. We used these often in the 80s on plant floor control systems that could not tolerate any sparks near combustible gasses. I've been thinking about this mod for a while and if/when I have time I will bench test such a setup to just one bulb to see what sort of heat we get from the transistor driving 150-200W load at 15V.
Here's a transistor that's good for driving 15Amps:
http://www.futurlec.com/Transistors/2N2955.shtml
And this one good for 25Amps
http://www.futurlec.com/Transistors/2N5884.shtml
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-07-2009, 07:02 AM
