SC Lambda questions
After doind many searches and reading TONS of posts, I decided to follow a select few's suggestion to disconnect the 02 sensor on my '80 Sc.
I immediately noticed a dramatic increase in power, smoothness and drivability of the car over a broad rpm range. Question 1: can the lambda system be completely removed from the vehicle? This leads to question 2: where exactly is the frequency valve and, can it also be removed from the system without having to swap out the entire CIS to an earlier unit? I do NOT want to convert to EFI ! The CIS WILL remain ! Souk, Tsuter.......THANK YOU BOTH FOR MANY VERY INFORMING HOURS OF READING !!!! I hope to have the chance to down a few cold ones with either of you someday !!!! |
1. Yes, anything is possible but it would invlove changing out a lot of components to do it right. It is not simply an "extra" added to a normal CIS system. You'd want to get a parts CD and compare what your car has with what parts are on the car you are trying to emulate, to get an idea of what parts to change. There were many, many little differences in the CIS cars from year to year and market to market. I would suggest sticking to a combination of parts that Porsche engineered to work together. Sort of pointless, if you ask me.
2. The frequency valve is located near the fuel distributor. It is a black cylindrical thing with a silver band in the middle and has a steel fuel line going in one end and a rubber hose at the other. There is also an electrical connector attached at an angle to the top, much like a cold start injector. When you disconnect the O2 sensor, the frequency valve is still in use. The control module sends a fixed duty cyle to it. So no, you shouldn't just yank it out. If you run without an O2 sensor, make sure that you have your CO set properly. JR |
The frequency valve is about 4" to the left (driver's side) of the throttle body, about 4" above the fiberglass shroud.
The lambda system is designed to keep your mixture close to stoich (14.7 to one) all the time except at full throttle and during cold start and warm up. If you leave it connected and everything is adjusted and functioning correctly, your engine will run clean, smooth, and with near maximum efficiency. If you disconnect it and adjust the CO to around 3 to 3.5, you will get more power and sacrifice economy and clean running. Why do you want to remove it completely? I see no reason to remove it, just disconnect the O2 sensor and the frequency valve goes to default setting. then adjust for CO and you are there if that is what you are after. |
To give you a data point on O2 sensor operation, here's an interesting mix for you:
I bought a 1969 911E with a 1979 3.0 liter engine and a 1980 fuel injection. It took me a few weeks to sort out what I have but this is what I noticed... -There is no 15 degree switch on the right valve chain cover. Since it's a '79 engine, the cover was never tapped for the temp sensor. -The O2 sensor wire is disconnected because without the 15 degree switch the O2 sensor is worthless. Since there is no 15 degree switch then there is always zero volts to the lamba brain. The brain would always think the engine was cold and always try to richen the mixture. -My frequency valve is directly between the throttle body and the firewall. Not too sure if that is the standard location. -I recently changed the plugs and they were dry and black with soot indicating a rich mixture. -Initial start when it's cold is a bit rough but smooths out within a minute. -It runs strong and smooth when warm. I am going to borrow an exhaust gas analyzer and lean the mixture out some. I plan on tapping the valve chain cover, installing the temp switch and reinstalling the O2 sensor...eventually. I want to see the difference. Hope this helps. I don't think the O2 sensor is terribly important. If I were to use her as a daily driver, then for the sake of fuel economy I'd have the O2 sensor. But for a few hundred miles per year, I'm not too worried. |
I tried to verify this with a used 15 degree switch I have in the parts box, but I couldn't get a closed circuit at room temperature, or even with running cold tap water over it which should have brought it down to 60 degrees F (roughly 15 degrees C). (Later I revisited this issue, and used a cup of water with a couple of ice cubes bringing the water temp down to 40 degrees F and got a switch closure.) |
Still the question remains, can the frequency valve be eliminated from the system ???
In a word.... No.
The fuel distributor for the '80 and on was intended to utilize the frequency valve to make the mixture adjustments for warmup, closed loop with the O2 sensor, and enrichment for acceleration and Wide Open Throttle (WOT). You can disconnect the O2 sensor and still have an operable system. If you remove and plug off the FV, you also lose the warmup enrichment, and acceleration and WOT enrichment. The Warmup Regulator that came as stock with the '80 does not provide the enrichment functions associated with the manifold pressure changes of earlier systems. So you will now be faced with at least swapping out the WUR for one that provides mixture adjustment. I am sure others have actually tried this, but I don't have personal knowledge of the results. Maybe someone who has actually done it rather than guess at it will post their results. |
Yes, you could eliminate the frequency valve.
Yes, it would be a major PITA and would require changing all kinds of parts and spending lots of money, basically backdating your entire CIS system to a 79 or earlier. No, it isn't necessary or worth it. Once again, why would you want to do it? |
OK, let me stray off just a bit.
I plan to turbocharge this car at some later date. Would the Lambda system (if functioning correctly) be able to enrichen the A/F mix during boost so as not to require the addition of an enrichening injector system ? My experience of better performance with the 02 sensor unplugged, i assume, is due to the lambda system not functioning correctly OR is it that the lambda system IS functioning correctly and the motor just enjoys being richened up, above the A/F ratio that the lambda is designed to provide? |
Paslantnose..!
Let me tell you .. The FV in my Porsche was disconected in the past by a nasty mechanic and let me tell you , It was a nigthmare man. Like Jim W . says don't disconect the FV, you wil l have a hell of a time. If you want to experience the behaivior of a 3.0 without the FV just disconect the electrical lead that goes to the FV and run the car. You'll see.Man VicSmileWavy |
My reason for wanting to eliminate the FV (IF i went that route), would be to do a "clean" removal rather than have stuff such as the 02 sensor sitting there unplugged.
For instance, say on a chevy some people just remove the AIR pump's belt. I would go all the way and remove the pump, control system and exchange the exhaust manifolds for ones without AIR tube holes JUST to make it a sanitary change with no remnants left as eye sores. As it has become evident that removing the FV properly would require backdating the entire CIS, that is what i would do if so inclined to eliminate the lambda system. Do it ALL or not at all mentality. Don't get the wrong impression, i might just as well be inclined to restore the lambda system to 100% correct and functional operation. For now, the car really likes the 02 sensor unplugged. Give the motor what it wants ! |
With the O2 sensor plugged in and functioning correctly, it will control the mixture corrctly, but at full throttle it is designed to go richer.
One thing I did was to hook up a hobbs switch that senses positive intake manifold pressure (turbo) and basically grounds the O2 sensor wire to the chassis under boost. that forces the lambda brain to tell the FV to go richer. That will provide enough fuel for 7 psi boost, maybe a little higher if you are intercooled but not much. If you plan to go much higher than that, you will need to do something to provide more fuel or to reduce ignition timing, or both. There comes a point (below 12 to 1) where more fuel will slow the burn and reduce the chance of pinging, but gives away torque, horsepower and economy. In that case you would be better off with retarded timing instead of going too rich. if your plan is to run more than 7 or 8 psi boost with pump gas you will have to either get creative or live on the ragged edge. I just hooked up my LM-1 and am still getting familiar with all the functions so I haven't yet figured out exactly how to use it to re-program the fuel mapping on CIS. My plan if I ever go higher with the boost will be to control pinging with timing, not extra fuel. |
Thanks, -Scott |
sammyg2, now THAT was the info i was looking for !!!
With mine being a 1980 SC with the 9.xx CR, i have been informed that 6-7 # of boost would be a safe limit. With that, and what you say about the lambda being made to go "full rich" via a pressure switch, the whole setup should work pretty well without having to add an enrichment injector correct ??? |
Kaefer, i know that the MSD ignition control (6AL) will accept the addition of a timing retard module.
Those module are normally activated by rpm or pressure switches so handling timing retard is very simple. |
Can the mixture be changed mechanically? I have a Scirocco with CIS and I eliminated the O2 sensor and had the mixture at idle adjusted (3mm allen screw in the air vane). It runs great and still gets great gas mileage. I know it isn't a 6 cylinder but the technology is the same. You don't want to eliminate the FV because that controls the fuel mixture. Usually it takes inputs from the O2 sensor but it will default to a middle of the road duty cycle when disconnected from the O2 sensor.
Hi,
As to removing the Lambda system: The metering valves in a fuel distributor (small plate valves) control the fuel flow vs. pressure for each injector. They are spring loaded and have a lower chamber, connected to the control pressure. On a pre-Lambda system they have a fixed bleed orifice to the fuel return. On a Lambda system that bleed orifice is replaced by the frequency valve. When the FV is open, more pressure is bleeded from the lower chambers and more fuel is metered to the injectors. If the frequency valve is closed, the chamber pressure is high and the engine leans out. If you remove the FV and plug the line, the engine would run so lean that it would barely run at all. If you leave the line open the engine would run so rich it would also not run well. The Lambda 'brain' opens and closes the FV about 50 times/second with varying duty cycle. That duty cycle controls therefore the bleed ratio of the lower chamber. When the O2 sensor is disconnected, the Lambda controller defaults to about 50% duty cycle during idle and part throttle. When the WOT switch closes (or the 15 degC switch closes) the lambda brain runs a constant duty cycle of about 60% (varies depending on engine) and ignores the O2. When the O2 sensor is connected, the controller regulates the duty cycle such that the O2 sensor voltage is about 0.45V. Regards, Klaus |
Good info Klaus. BTW, i am very happy so far with the LM-1.
I have a question for you though, I have been told that grounding the lamda sensor wire will fool the FV to go rich also. Is that basically the same thing that the WOT switch is doing or will grounding the wire make it go even richer than at WOT? paslantnose, The stock CIS will add enough fuel in a turbo application up to around 5 or 6 psi with no additional enrichment or tinkering needed. The original BAE kit was designed to bolt onto a stock engine and run 5 psi with no FI mods. Above 5 or 6, extra fuel is usually added or timing advance is taken out to prevent pinging. So if the dizzy was modified or the ignition mapped to take out about 5 degrees or so of advance under boost, the stock CIS would be more than capable of correctly metering the right amount of fuel with 7 psi, maybe 8, maybe higher. I haven't done enough testing to find out where that threshold is. BTW, a 1980 3 liter engine with 7 psi boost is loads of fun and safe for the engine, as long as it doesn't run lean or have too much ignition advance. You may find that is all the power you need. |
Th original BAE manual details a modification for the distributor that locks out about 5 degrees of mechanical advance. I haven't done it because I feel it is beyond my capabilities. I don't have a distributor advance machine so it would be difficult to measure and make sure I got it right. one of these days i will probably send it out and have it modified by a pro.
I believe Tsuter had it done to his dizzy. Of course an easier way would be to just set it at zero degrees BTDC instead of 5, but it would prolly idle and run like crap when not on boost. |
sammyg2, again.....beautiful words to hear.
My intent with this motor is to constrain myself within the limits of the system with 6 or so # of boost and make that work the best i can. If that becomes "not enough", it'll be time for a 3.2 or something else to go in. Playing around today (i bought THE allen wrench), i followed advice and began richening up the A/F a 1/4 turn at a time while it was running. The richer i made it, the higher the idle climbed. OK i'm thinking, let me lower idle speed screw a bit. I backed the idles speed screw off until it was evident that the throttle plate was FULLY closed and the idle speed screw was no longer in control. Hmmm, lemme check. Nope, nothing holding it from going any further closed, the throttle plate IS fully closed yet the idle is still at 1500 !!! Am i to assume at this point that my next mission is to locate and correct the vaccuum leak(s) ??? THEN, readjust the A/F mixture and idle speed. |
PS
The car just became a whole bunch more fun to drive !!!!! "Nellie, hold onto your hat and paleezz pull your teets back in the car !" |
Playing with the a/f mixture is something that you need to be very careful with. A very small turn of that screw makes a large difference and it's easy to get it way out of adjustment.
It is normal for the idle to climb a little when it is richened up, but maybe not as much as you described. The idle speed adjustment screw isn't a throttle stop, it is a bypass metering screw that lets air go around the throttle plate. If you have it screwed all the way in and the idle is still too high, check your throttle linkage to make sure it isn't holding the plate open. If the throttle plate is against the stops isn't held open by the linkage, and the screw is turned in all the way and the idle is still at 1500, I'd say you have a large vacuum leak. |
The srew i'm calling idle speed has a locknut on it and actually does contact the throttl arm acting as a "stop".
I did see another screw going sideways into the TB that may be what you're talking about ? |
Oh, OK. The one you adjusted is one of those DON'T TOUCH kind of things.
There is a large screw with a spring under it that sticks out the left side (driver's) of the throttle body, that is the idle speed adjusting screw. You will need to re-adjust the stop plate screw to factory settings, I don't remember what the factory setting is off the top of my head but it is an important setting. Once you get that set correctly, use the bypass screw to adjust the idle. One more thing to check, after you get everything set, make sure you are getting full throttle. Lots of times the bushings or linkage gets worn or loose on these cars and the throttle body will only open 3/4 of the way. If that is the case with your car you will get plenty of extra free horsepower by getting rid of the slack and you will owe me a beer ;) |
Hi Sammy,
A quick and dirty way (without AFR control) is to disconnect the WOT switch from the Lambda brain (so it stays in closed loop) and then instead use the WOT switch to ground the O2 sensor. THAT will cause it to go full rich at WOT only, but then you might be too rich before boost comes on and you might have rich bogs when going to WOT from low rpm. Whenever you disconnect the WOT switch, disconnect it at the switch itself ONLY, not at the Lambda brain. The 15degC switch is wired in parallel to the WOT switch and grounds the WOT-input to the Lambda brain when the engine is cold. This causes the Lambda brain also to go to it's default WOT setting (and ignores the O2 sensor). You want to retain than function. Regards, Klaus |
I think I have a new hero. Klaus, you are the man. :)
The hobbs swith I have connected closes at 3 psig rising in the intake manifold and grounds the O2 sensor, making it go rich. Based on your explanation that does make it go very rich under boost EXCEPT at full throttle, obviously there are better ways to do it and the LM-1 is going to get me there. Basically the only time I hit boost is under full throttle, so the hobbs switch is useless. While I am well schooled in the mechanical field, my skills in electronics are limited but I am learning with the help of folks like you. thanks again. |
Going back to the original issue:
If the car runs better with the 02 sensor disconnected, then why not just replace the O2 sensor? They're fairly inexpensive, and they do wear out... ianc |
Mainly due to what i have read where the lambda system is designed to keep the CO around .8% when the cars seem to like 3-3.5%.
The whole reason for disconnecting the O2 sensor (besides those who don't want to fix something that is broken) is to set the mixture the way you want it, instead of the way the O2 sensor wants it.
Some folks like the little bit of extra torque available from a mixture just on the rich side of stroichiometric and are not concerned that much with maximizing economy or minimizing emmisions. I prefer to have a fully functioning O2 sensor, some others don't. |
To add to what sammyg2 said:
Last but not necessarily least, if your car should have a catalytic converter, disconnecting the O2 sensor and running a much richer mixture than stoichiometric will result in the early demise of the cat. The main reason for the implementation of the O2 sensor was to put the air/fuel ratio in a range to make the cat do it's job. |
Personally, i've never liked the furry little bastards !
Hi,
just FYI, One of my engineers collects and races old Ferraries. One of them has dual CIS-Lambda with two O2 sensors (one in each bank). He reprogrammed two of our LMA-3 Auxboxes to act as 'mappable' Lambda brain in conjunction with 2 LC-1's. The original Lambda brains are not used in this case. The CIS system with that is now programmable with a 16 x 16 desired AFR map based on manifold pressure, intake air temp and RPM. Also has programmable accel enrichment. All done via the frequency valves. The MAP sensor in the LMA-3 can already handle up to 2 bar of boost. If there's enough interrest, we can productize something like that as a kit for around $480.- to $500. Regards, Klaus |
I found this thread because my plans with a late SC motor are to run it in an early car without the lambda system entirely, so I'm looking for a way to control the frquency valve or use another enrichment system to make the engine usable. What would be the simplest way to do this?
Change your Fuel Dist.
VicSmileWavy |
Vic writes:
If you go this route, you would also need to double-check that the throttle body used with the Lambda CIS has the proper port to feed the vacuum connection on the earlier WUR. I think this port may be just a straight shot to the intake manifold, but it could be located in a place that gives some transition from partial throttle. I think I have both types of throttle bodies, I could check on this if you decide to go this way. |
Klaus, the programmable LMA-3 is something I am interested in but since I just bought a new LM-1, seems like I'm a day late and a dollar short.
Is there anything that can be done with the LM-1 or is it basically no longer needed if I bought the system you decribed? |
