Deviant
timlooney's Avatar
Name those connectors
Can anyone name the two connectors shown in the figure (see white arrows). I am trying to figure out where they go or they are "extra". One has two round connections and the other has two flat connections.
TIA
Tim Looney
'82 911 SC - sold....
Old 02-01-2006, 07:28 AM
jdowty3's Avatar
I have the same extra connector with the round terminals. I think the other one with the yellow and brown wire would go to the blower fan if you had not backdated the heat system.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 02-01-2006, 07:31 AM
yellow and brown are the rear heater blower the other looks like the connector for the thermo VALVE...THERMO VALVE !! The Thermo time switch lives on the timing chain cover and switches on/off the cold start valve. THE THERMO VALVE controls the vacuum going to the WUR.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 02-01-2006, 01:43 PM
Deviant
timlooney's Avatar
Please excuse my ignorance but what is the thermotime valve?
Tim Looney
Old 02-01-2006, 01:50 PM
Designer King
Paulporsche's Avatar
In CIS cars the thermaltime switch controls when and for how long the cold start valve injects fuel upon startup.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-01-2006, 02:13 PM
jdowty3's Avatar
The thermotime switch connector is different and the wires on that unknown connector would never reach to the thermotime switch.
When I pulled and cleaned my motor last winter, I found the same unknown connector hanging loose and just tucked it out of the way.
Jim Dowty
Gruppe B #309
Old 02-01-2006, 04:58 PM
oneblueyedog's Avatar
The one without the prongs goes to the heater blower fan. The other goes to a little plastic round thing with 2 vacuum hoses connected to it. It's located under the blower on a bracket that holds the fuel return line. Hope I'm right.
78SC coupe, Silver Metallic
Old 02-01-2006, 05:06 PM
I think this is the thingy.
Old 02-01-2006, 05:10 PM
Old 02-01-2006, 05:21 PM
lol
Old 02-01-2006, 05:24 PM
syncroid's Avatar
oneblueyedog wins the prize!
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
jdowty3's Avatar
what is the 17A "thingy" and what does it need power for? Was it something for the highly de-smogified west coast cars?
Jim Dowty
Gruppe B #309
Old 02-01-2006, 05:29 PM
Deviant
timlooney's Avatar
Well, my car didn't come with a blower. I think it may have been removed by a PO. So I guess I will just let Herman and Cletus hang out... lol
Tim Looney
Old 02-01-2006, 06:16 PM
Unregistered
sammyg2's Avatar
That item (17A) is an auxiliary air valve and it does not have any electrical connections on it.
Old 02-01-2006, 07:42 PM
Here' mine-
Old 02-02-2006, 05:30 AM
Deviant
timlooney's Avatar
Thanks oneblueyedog, what side of the motor is that? Top left?
Tim Looney
Old 02-02-2006, 06:23 AM
There is an auxiliary air VALVE and an auxiliary air REGULATOR, which are not the same thing. The auxiliary air regulator is also known as the supplementary air valve in the wiring diagrams, where the astute reader will note the presence of a connector with two wires (red/white and brown.) Ya gotta love Porsche and their consistent documentation.
Anyway, I'd venture to suggest that Herman needs to be plugged into the auxiliary/supplemental air regulator.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 02-02-2006, 06:26 AM
"The thermo valve holds off vacuum from the warm-up regulator when engine is started cold ('77 - '79 engines). Power is applied to the thermal valve when engine is started, and approximately 30 seconds later, the valve opens. When the valve is open, vacuum to the WUR is then determined by the intake manifold. --The vacuum holdoff results in a mixture richening at warmup. The inner hose connects to the intake vacuum source and the outer hose to the WUR." JW
http://www.pelicanparts.com/catalog/images/fuel_injection/new_images/fi_fielsystem_1-7-2d17a.jpg
Peace, Ron
www.ronorlando.net
Old 02-02-2006, 07:01 AM
Deviant
timlooney's Avatar
Does that still apply if my engine is an '82?
Tim Looney
Old 02-02-2006, 07:13 AM
77 to 79...maybe someone changed the harness or the engine??
I looked at the connectors for the freq valve and throttle switches they are different from the one you have shown..which is what I have on my 78 going to the thermo valve. Do you have the lambda system? maybe its time to check serial numbers.
Peace, Ron
www.ronorlando.net
Old 02-02-2006, 07:44 AM
