Using a direct drive polisher to polish paint . . . any tips?
As I've found, a random orbital with the proper nonaggressive pads and polishes is pretty mild and risk-free.
But looking to go to the next level! Colorsanding and polishing it out.
Tried it on a trunklid, laid down some paint, 2000 grit wet sand, but the random orbital doesn't cut it to polish it out. Not compatible with the heavy cut cleaners, which seem to require 1000 or so rpm of direct drive polishing. Even the 2000 wet sand paper leaves cuts too deep for a random orbital.
So I'm going to try a direct drive with Meguire's cutting polishes and pads.
Any tips? Other than start slow and be careful?
Old 02-01-2006, 08:35 PM
ruf-porsche's Avatar
Get the correct pad for each cutting polish and don 't mix the pads.
Here's my before and after shot of my BMW roof spray with a rattle can spray and polish / buff.
Before
After
Old 02-01-2006, 09:03 PM
Air Medal or two
afterburn 549's Avatar
really not too much to it.....mostly do not concentrate in one spot too long...esp with a "rubbing / polishing compound. Better to do too little then too much as you can always go back over it
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-01-2006, 09:32 PM
PeteT's Avatar
Watch those edges!!
1983 SC
1958 TR3
2014 Cayenne GTS (wife' car)
2006 KTM 450EXC
Old 02-01-2006, 09:38 PM
bigrubberjeep's Avatar
Like everyone else has said, start with a light compund, let the pollisher do the work and don't burn th epain by overdoing one spot too loong. Kinf of like a "wax on /wax off" motion but with a polisher -
Can't ever say that phrase and not remember the man.
RIP Mr. Miagi
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 02-01-2006, 11:50 PM
I need to do this too. Any recomendations on specific polishers, pads,
compounds and where to get them???
Thanks,
Mike
1985 Carrera
1995 325is
2000 Grand Cherokee
Old 02-02-2006, 07:23 AM
wcc wcc is offline
wcc's Avatar
I can't remember if I have the 847 or the 849. I can check when I get home. But here is a link to a good polisher. Use it on the LOWEST setting:
http://www.dewalt.com/us/products/tool_detail.asp?productID=173
Then buy the "Hook and Loop" or "hookit" type backing pad. Then the 3M rubbing and polishing pads for it. Then get the 3M imperial Hand Glaze. Lastly, put on your wax for protection.
This is just what I use.....
Bill
997.2
Old 02-02-2006, 07:42 AM
