CV Joint bolt removal
Okay, so I am tryiing to remove a torn CV joint boot, get 5 of teh 6 bolts out (6 mm allen), but the 6th refuses to move and appears to have had the inside stripped out so that the allen wrench will not engage, what now?
Old 02-01-2006, 11:42 AM
Priced-out of Porsches.
mmastro's Avatar
Maybe penetrating oil and vise-grips? I feel your pain.
Mike
SoCal
Old 02-01-2006, 11:57 AM
She/Her
BeauBlues's Avatar
I second that on the vise grips. Works for me.
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 02-01-2006, 12:12 PM
Ditto.....
Oil, tap, sit
Oil, tap, sit
Oil, tap, sit
grip...................
Patience, my son, patience......................
Bob
Old 02-01-2006, 12:29 PM
I ended up having to remove the other end of the joint, then use an air grinder to saw it off
Good luck...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 02-01-2006, 12:40 PM
Kelly Bell's Avatar
When I did it, this worked every time:
you take a die grinder or body grinder, and grind a slot in the side of the bolt head, parrallel to the bolts length.
Then using a hand held pneumatic air hammer ($25) and a chisel adapter in it, place the chisel head into the slot, slanting it so it will back the bolt out when the bolt begins to move. Make sure you are wearing goggles and let the air hammer rip. Works every time.
Course, you are gonna have to get a new bolt.........
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 02-01-2006, 01:40 PM
Well, I've sprayed it again with oil, then opened a nice Trappist Ale, and will wait till tomorrow. WIll let you know what happens....
1980 ROW SC
1986 944
looking for a 914
2008 4 Door Wrangler
Old 02-01-2006, 01:42 PM
911mot's Avatar
Hammer a 3/8" drive torx bit into the stripped out portion and then use a ratchet and extension on that
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 02-01-2006, 01:57 PM
what size torx bit?
1980 ROW SC
1986 944
looking for a 914
Old 02-01-2006, 02:02 PM
AvonGil's Avatar
id cut it off. If you have a 90deg die grinder it will take you 3 min.
95' Mercedes E300 Diesel (Azure+Sodalith Blue)
88' Porsche 911 Targa (FOR SALE) (Guards Red)
Old 02-01-2006, 02:10 PM
Kelly Bell's Avatar
I like the ale idea...................
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 02-01-2006, 02:17 PM
Just squirt some more ale on the bolt and am drinking some more penetrating oil,
whoops, wrong order......
1980 ROW SC
1986 944
looking for a 914
Old 02-01-2006, 02:26 PM
onefstm's Avatar
Send a message via AIM to onefstm Send a message via Yahoo to onefstm
This happened to me a few months back. If you use a die grinder or dremel to cut into the washer behind the bolt, then grab the remaining portion of the washer with a pair of pliers and remove it, all the torque that has been applied to the bolt will be released and you will be able to turn the bolt out by hand. Hope this helps.
Old 02-01-2006, 06:09 PM
This has happened to me several times, I just use a easy out. Quick solution!
Steve Larson
Dana Point, Ca
84 Cab, lots of TLC
Old 02-01-2006, 08:04 PM
Thanx for all the help! A bit of penetrating oil, a new set of Vise Grips (on the clearence isle at Home Depot), oh and a Dremel cutting disc or two, and the bolt was out! New boot on, filled with grease. New shocks on, new sway bar bushings--just waiting for the tires to be mounted, should be on the road by tomorrow afternoon!!!!!!
Celebrating with a St. George's Ale!
Life is good.
1980 ROW SC
1986 944
looking for a 914
Old 02-02-2006, 04:04 PM
Kelly Bell's Avatar
Excellent. Put some ale on it and have a drink of grease for me!
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 02-02-2006, 04:10 PM
emcdan's Avatar
vise grips and a tap with a rubber hammer......no doubt....just make sure to have a couple of bolts in to keep the cv from moving
Deutsche Fahrzeuge
78' 911SC
03' 325I BMW
03' KTM 450sx
05' S2000 (daughters)
Old 02-02-2006, 04:33 PM
