O2 Connector Problem
I have a connector to the O2 sensor that I need to repair. Any ideas? See the pictures.
http://forums.pelicanparts.com/uploa...1139076807.jpg http://forums.pelicanparts.com/uploa...1139076829.jpg |
Some one has to know where to get a new connector for this.
That connector is part of the wiring harness and is not available seperately.
Here is a link to a thread that addresses this very subject: http://forums.pelicanparts.com/porsche-911-technical-forum/182054-what-part-am-i-looking.html?highlight=sensor |
Make your own connector. Cut the wires, spice solder and conect. Just make sure that the harness side is truly trashed
first. regards, Steve |
Thanks guys, I was afraid of this. Oh well, the soldering pin is my friend. Any water tight connector okay or do you have a suggestion?
Just about any connector will do as long as it is insulated and will keep the water out. I would use a crimped connector instead of soldered, but that's just me.
| All times are GMT -8. The time now is 01:51 AM. |
