O2 Connector Problem
I have a connector to the O2 sensor that I need to repair. Any ideas? See the pictures.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
Some one has to know where to get a new connector for this.
Unregistered
That connector is part of the wiring harness and is not available seperately.
Here is a link to a thread that addresses this very subject: What part am I looking for? |
Location: member Central PA Region PCA , Home of the Hershey Swap
Make your own connector. Cut the wires, spice solder and conect. Just make sure that the harness side is truly trashed
first. regards, Steve
Steve Frequent Pelican Customer 1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more 2002 996 TT X50 (H&R Springs) 2002 WRX in WRX Blue Proud Rennlist Charter Member Support and Join Rennlist.com An Expert on absolutely nothin' more than my own opinions! 2002 WRX in WRX Blue Last edited by rbcsaver; 02-04-2006 at 06:40 PM.. |
Thanks guys, I was afraid of this. Oh well, the soldering pin is my friend. Any water tight connector okay or do you have a suggestion?
Unregistered
Just about any connector will do as long as it is insulated and will keep the water out. I would use a crimped connector instead of soldered, but that's just me.
