Gettin' picky. (Fri. afternoon bodywork pics)
I thought I'd share some technique with you guys. As you can see, the hood on the 911 has some damage. The PO's body man beat it down and filled it. After stripping the paint and grinding off the bondo, this is what it looked like
I then used the body file to highlight the lows In the close up, the straight lines show what's even I went under and used the pick to raise the low dents After some dolly work, I had a little oil can from stretching the metal and there are some low spots over the underbracing that I can't get to from the back. So I raised them with some heat and shrank the metal with the sopping wet sponge. [img] There are a couple of low spots over the underbracing that will have to get filled. Not bad for a couple hours. The rest of the car won't be as easy. I'll keep the progress posted. |
Finished for the day.
SCWDP- Shock and Awe Dept
Wow! Is this the same car you were cut off by the Boxster in? Can be!
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Did you get the memo?
Looks like a job well done. Are you restoring the car Milt, or just doing a little repair?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
you're a sick, sick man...
![]() Amazing work. |
never ending projects
Congrats, your work looks really nice. A couple of years ago I had to fix a roof line with similar damage but was afraid to use heat. I used dollys hammers and files but if I had it to do over, I would use those "weld on" tabs that attach to a dent puller. Harbor Freight has them cheap enough to experiment with. Chuck
I am impressed! Good work.
Chuck Moreland - elephantracing.com - vonnen.com |
A tool I didn't show is a thin "slapper" that I can insert behind the underbracing and work closer to the pinch seam. There is some serious cutting and patching coming up in the next few days. All the tools will get used and shown at one time or another. |
19 years and 17k posts...
Milt,
Great work, the car is going to be beautiful!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Wish I had the skill for something like that.
Michael
1984 Carrera Targa Sold to fellow Pelican 1973 911S Targa - Sold to fellow Pelican. |
I think it takes skill and patience, two things I am dreadfully short on...
Thanks Milt!
That's awesome (and very informative for those of us who are just delving into the world of sheetmetal). I'm looking forward to more posts. Keep up the nice work.
Clint 73T mfi coupe 87 gli sedan 87 535is 5speed (the newbie) |
What?
Well done! I wish I had that much time and patience!! Can I send you a few body panels to work on?
Tom J. 911SC Cab SCWDP CaymanS |
No wonder MikeZ was raving about your work when he started disassembling Manfred!
Please keep us informed of your progress, I enjoyed seeing the tools/techniques...
72 Porsche 911T/E Targa 72 Porsche 911S 85 BMW 735i |
Good Stuff! I'm starting the process of stripping down a front fender because of some checking...found some filler in low spots. I want to fix with a min amount of filler so, thanks for the thread!
1985 redslope 930, 8:39 RP, S cams, B&B dual out muffler, IA Fuel Dist. Sitting on shelf awaiting installation: IA HF turbo, GSF headers(no heat), 46mm wastegate. 1971 911T Targa. needs alot of work(understatement).
