dan79brooklyn's Avatar
heat backdate question
OK- I have removed all the AC components and am now considering removing the heater blower and backdating the heat.
(1979 SC)
This is my question :
Were is the heat routed to? does it just get expelled from behind the fan and disperse or is routed back into the heat exchangers?
I am not so familiar with how the heat works in my car. I have SSI and dual B&B (from the PO) on the car if that makes a difference and I would like to keep the somewhat adequete heat which the car currently delivers, but like the looks and simplicity of the backdate.
Thanks for the edification,
Dan
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 01-27-2006, 12:56 PM
ianc's Avatar
In stock form, air is blown by the engine fan through that black plastic accordian shaped hose to the blower fan. The fan housing has a Y pipe that diverts the air to each of the two heat exchangers. From the heat exchangers, it goes to the flapper boxes, which route the heat forward to be distributed by the confusing array of levers in the dash.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 01-27-2006, 01:09 PM
So when the heat is backdated the tubes that come out of the rear of the heat exchangers is simply routed to the engine fan and the heat is blown out through the fan?
EX - 1976 BMW 2002
Old 01-27-2006, 01:19 PM
dan79brooklyn - you've got the flow of air backwards. The large engine/alternator fan sucks air in and blows it fowards towards the cylinders. Some of the air is diverted towards the sides of the fan housing. In stock form the cool air that comes out of the left side of the housing goes up the tube to the heater blower which boosts and splits cool air down to the left and right heat exchangers. The air is heated and the heater flapper valves either dumps the heat if the heat is off or moves forward to the cabin if the heat is on. When you backdate you remove the heater blower and associated tubes and replace the left and right output ducts of the fan housing. Some of the cool air will now move directly out the left and right of the engine fan down to the back of heat exchangers.
Old 01-27-2006, 01:52 PM
I got it! Thanks guys.
EX - 1976 BMW 2002
Old 01-27-2006, 02:20 PM
Dan in Pasadena's Avatar
Now, does anyone know a good (cheap?) source for the right side backdate duct for my '76 2.7? I have the driver's side, I just need the other one and don't want to spend $130 for one of those fiberglass ones. I've got plenty of other $130 things to do!
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 01-27-2006, 02:56 PM
PatrickM's Avatar
Dan, your best bet a salvage yard or parts place like Parts Heaven. I picked mine up at Gary Emory's place in McMinnville, Or.
Check one of these places.....
http://20thstreetauto.com/parts.htm
http://oklahomaforeign.com/
http://www.partsheaven.com/
http://www.911pcar.com/
Old 01-27-2006, 05:45 PM
Hit the junkyards, swaps, and Pelican classifieds.
I encourage people to find used right-side ducts - they are a royal PITA to make
Old 02-07-2006, 08:30 AM
